immobiliser light flashing 5 times
dont know if you guys can help cause its a uk car but my dad was wondering if any of you guys know the code for immobiliser light flashing 5 times its a 94 prelude h22a5 could really use some help cheers
Ah, man I forget.. I think mine flashed 5 times when I had a key cut for my Lude's key cylinder but the code programmed for my brother's Lude's ECU (had some issues after a swap and thought it may have been something with the ECU). IIRC the Immob flashed 5 times either then, or when I had my ECU and my key but stuck his Immob unit in. I'm guessing one of the two isn't recognizing the code, but I may not be remembering correctly
