The end all Differences/Changes 02-04/05-06 RSX Thread
Surje.motorsports
maybe we can get this stickied somewhere in one of the 7 sticky threads we have lol
Changes from 2004 to 2005
Canadian 2004 RSX Type-S Interior
2002-2004 Satin Silver Metallic RSX
2005 Tafetta White RSX
Revised suspension tuning for increased handling precision and a smoother ride
Ride height reduced by 7 mm
Optimized damper and spring settings
Firmer stabilizer bars (front and rear for Type-S, front for RSX)
Bushings at suspension installation points were optimized
Inversely wound front coil springs
Refined steering system for enhanced feel and quicker response
Swifter steering ratio
Stiffer steering column
Pump flow increased by seven percent
Kickback reduction valve
Optimized braking system for enhanced stopping power and feel
Pedal stroke decreased
Master cylinder diameter increased
Brake pedal toe rigidity increased
Larger diameter 17-inch sport design alloy wheels and 215/45R17 all-season high-performance tires
Body rigidity increased 15 percent in front and 21 percent in the rear through the application of reinforcements at key areas
Vehicle noise and vibrations reduced
Engine damper added to front subframe to reduce engine rocking and vibration transmitted from the engine to the cabin
Insulation material added at key points on doors and roof to reduce road noise
Side-mirror gaps sealed and weather strip added
New front and rear bumper designs
Redesigned headlight and taillight assemblies
Restyled signature 5-sided Acura grille
Redesigned side sill garnish
Four new exterior colors: Magnesium Metallic, Vivid Blue Pearl, Jade Green Metallic, Blaze Orange Metallic
Freshened interior design
Deeply bolstered front seats with thicker cushions
New chrome and titanium-look accents
Meter faces changed from metallic to white
2005 & 2006 RSX Type-S Additional Enhancements:
The engine intake and exhaust modifications that boost the power of the Type-S models to 210 hp (157 kW) at 7800 rpm, compared to 200 hp (150 kW) at 7400 rpm on the previous model.
Higher performance camshafts sourced from the Type-R engine
Air intake duct enlarged for increased air flow
Larger diameter exhaust pipes to increase exhaust flow
Catalytic converter optimized to reduce exhaust back pressure
Larger diameter front strut tower bar
Bushings replaced by bearings on strut mount
Deck lid spoiler
6-speed transmission optimized with a lower final gear ratio for quicker acceleration and carbon synchronizers replacing brass on 5th and 6th gears for a smoother shift feel
Deck lid spoiler
Ok, so I updated the link in the FAQ thread with this URL. It's a shame that all of this information is readily available, the problem is people actually looking for it and actually using resources available to find it.
On a side note, I have been putting off updating the FAQ thread for a really long time now. I will actually be buckling down and updating it here very soon with more modern information.
rsx.type.s
11
Apr 24, 2009 03:33 AM
jdmintegralsvtec
Sep 25, 2006 05:06 PM
