GSR crank vs. ITR crank
I am building my motor and am needing another crank. I am building my ITR motor for more boost and am wondering is there a difference between a GSR crank and a ITR crank?
If so, what are the differences and since I am building the motor, would it matter which one I use?
THanks
THanks
Nope there the same nothing speacial, but remember when you get one make! sure its reburished and miced and ready for install, do not buy a used one not knowing if its repairable or not! and stay away from aftermarket cranks they are no good trust me!! oem is the best i know 600+ b series running oem cranks. oem cranks are hard to find sometimes and if you are helpless i have a gsr crank i can get checked and if its repairable its yours for cheap just pay for the reburish so gl
i wouldnt worry though, just balance and polish the gsr crank and youll be fine. also less rotational mass.
If you're building the engine and dont currently have a crank, scrap either of those options and invest in the LS crank. The longer stroke adds to your displacement and ability to generate torque. Thats just my .02
Integ03
21
Nov 2, 2003 07:35 PM
aftermarket, balancing, crank, crankshaft, crankshafts, differences, gsr, hondatech, install, integra, itr, oem, oklahoma, owm, type, versus
