Multi point wiring harness obd1 stuff
Ive got an obd1 ecu jumper harness and an obd1 si wiring harness. So obd1 is an easy conversion, i need help with multi point. The jumper harness is assuming the car is already multi point. So i dont have to pin anything in or out. Just cut the injector wires on the jumper harness and connect them to the injectors. Only problem is i dont know which ones to cut.
just need to know which wires out of the obd 1 ecu are for the injectors??
If I'm not mistaken, it sounds like you want to hard wire (in a sense) your fuel injection straight off the ECU via the jumper harness... If so, do as the first person said and search. Look in the FAQ in the 92-95 Civic forum. If all else fails, google it.
^looks like your the only one that got what i was saying. I did look at the FAQs and stuff but its kinda confusing trying to figure out which wires off the jumper harness to cut. I just wanna know exactly what wires from a p28 go to the injectors. But seeing is how everyone is against me, ill go search again...
LOL I'll see what I can find...if you don't find it first.
EDIT: Found this one
http://www.superhonda.com/forum/f55/...inouts-217405/
88_hatch_ls
56
Sep 18, 2013 01:51 PM
Choy
Feb 25, 2010 03:07 PM
jdmdikk
Apr 15, 2009 07:55 AM
