Sway bars
Old Apr 29, 2010 | 12:12 PM
stevej1's Avatar
Default Sway bars
I'm lookin to buy a sway bar for my ej1 and i was wondering if the gsr end links would work or if I have to get different ones. Also if I need some sort of sub frame support for such a small bar?
Old Apr 29, 2010 | 12:17 PM
-Gambit-'s Avatar
Default Re: Sway bars
any swaybar less then 18mm you will be fine without any added subframe support. when you go bigger you will need to add a asr or the beak subframe re-enforment (not a beaks lower tie bar)
Old May 10, 2010 | 11:32 PM
stevej1's Avatar
awesome. the endlinks will bolt right up?
Old May 11, 2010 | 12:11 AM
tunedX's Avatar
On the same topic.... Would EG endlinks work with ITR bar?
Old May 11, 2010 | 06:16 AM
Vindicator9000's Avatar
318 Curves, 11 miles
An EJ1 is a 92-95, right?
Okay, so there are generally 4 main styles of lower control arm. Which endlinks you use are determined by which style of lower control arm you have.
First are 92-95 Civic LCAs with no endlink mount at all. If you have these, trash 'em.
Then, there are the 92-95 Civic/Integra style with the endlink mount on a standoff on top of the LCA. Integra endlinks will work on these with proper geometry, and I think EG Civic endlinks should work as well.
The ITR LCAs are completely different from the EG style, but use the same endlink and location.
The 96-00 Civic style have the endlink mount through the middle of the LCA. You need a completely different endlink (99-00 Si style) for these.
If you go with aftermarket LCAs, beware. Most of the cheaper ones have the endlink mount in the EK location, which completely screws up the geometry if you use EG endlinks.
I just went through this doing a mix-n-match swaybar setup on my EK (well, EJ8), and that's what I found.
Old May 11, 2010 | 10:29 PM
stevej1's Avatar
ok thanks. I have aftermarket no name lca's so idk how it will mount up but i'll play around and see what i need to do.
Old May 12, 2010 | 05:51 AM
If you have aftermarket LCAs, where is the endlink mount location?
If it protrudes from the top, you need EG/Teg links. If it's in the middle, you need Si endlinks.
Old May 12, 2010 | 11:08 PM
stevej1's Avatar
ok. cool. Will the rest bolt straight up to the subframe? or do i need to run a bolt and nut combo? haha
Old May 13, 2010 | 05:22 AM
well, the ASR will come with everything you need to bolt it to the subframe.
However, I'm not sure which OEM D brackets fit on the ASR brace. You'll have to find D brackets that fit the ASR, and bushings that fit the bar. I used universal Energy Suspension D brackets with the 22mm bushings, since I have a 22mm ITR swaybar.
I got the universal ES brackets from Summit Racing for like $12. If you can find ones that are the right size for your swaybar, that's what I'd recommend.
Old May 13, 2010 | 07:13 PM
stevej1's Avatar
ok awesome. I got everything bolted up nice and got some new blox adjustable endlinks for it. got it on and it feels like butter!
http://hphotos-snc3.fbcdn.net/hs313....4_662026_n.jpg
spooncivic1
Suspension & Brakes
Oct 25, 2012 02:30 PM
MattNYC
Jan 22, 2010 10:18 AM
Cream
Suspension & Brakes
23
Dec 7, 2006 11:25 AM
hatchy
14
Jul 9, 2002 04:53 PM
hatchdrvr
Mar 24, 2002 05:34 PM
