Convert cable speedo to electronic?
Old Apr 28, 2010 | 08:58 PM
jrose152's Avatar
Default Convert cable speedo to electronic?
i have a ls tranny in my car and its a cable speedo. my tuner told me i need to have an electronic speedo instead of cable to do stuff like launch control through my chipped ecu, how do i go about converting?
after some searching...all i need is a new cluster and a electronic vss assembly? im running a DA dash swap with DA cluster so mabye ill get a gsr cluster? can someone explain this process in detail?
Old Apr 29, 2010 | 09:08 AM
jrose152's Avatar
Default Re: Convert cable speedo to electronic?
tttttttttttttttt
Old Apr 29, 2010 | 09:23 AM
ridgeapd's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/electronic-vss-90-crx-2261254/
http://hondacrx881.tripod.com/gsrclusterswap.html
You should be able to figure it out from there, I hope.
Old Apr 29, 2010 | 10:43 AM
D16SiHatch's Avatar
your tuner is incorrect. the speedo may be cable driven but your cluster still converts that mechanical rotation into an electrical pulse which is then sent to the ecu, pin B16.
Old Apr 29, 2010 | 01:13 PM
JCRXTURBO20916's Avatar
D16SIHatch is right, i have a cable trans and i have launch control. im using hondata
s300 never had a problem./
Old Apr 29, 2010 | 01:15 PM
tell your tuner to get out of tune. he dosent know what he is talking about.
peanut butter
Feb 18, 2008 04:00 PM
JapJunkie
13
Feb 1, 2007 02:30 PM
gsxr1k05
Sep 3, 2006 10:52 PM
93egryda
Mar 15, 2006 11:16 AM
cutt
Nov 12, 2004 06:57 PM
