b18c1 gas mileage problem. is this normal?
Old Apr 28, 2010 | 08:36 PM
tekstyle's Avatar
Default b18c1 gas mileage problem. is this normal?
My car has been getting crap gas mileage consistently and I am beginning to worry that it's not just from age, but from a mechanic problem. Recently, my mostly city and mostly highway mpg vary very drastically. if anyone have any clue or have a similar experience, please give advice, thank you. Here is the health history of my car.
1.5 years ago: blew a the fuel line connector at the fuel pump. brought it to a shop and got that fixed with a new plastic clip. same pump.
a year ago: gets about 24city/30highway/ 26-27 mixed
3 months ago: got it smogged and passed.
now: 20mpg city/ 23 mixed/ estimated 26 highway (never had the chance to take drive it on the highway for extended period to confirm)
driving habits:
5 days of the week is city driving (70 miles total). other 2 days are highway (45miles total)
rev to 2500rpm when taking off from a stop. (there's a lot of hills)
shift at 3500 or 4000rpm.
typically cruising at around 2000rpm most of the time, but sometimes up to 2500rpm
stock b18c1 with: (I'll try to be as detailed as i can)
hondata thermo intake manifold gasket.
greddy catch can
NGK platinum plugs
aftermarket spark plugs (cables look smaller than stock ones)
airbox intake
fidanza 7.5lb flywheel
polished intake and exhaust ports
honda crankpulley but not stock. it has a smaller alternator and power steering pulley.
mishimoto oversized all aluminum radiator with 50/50 mix coolant and wetting agent additive
mobil1 10w30 synthetic oil
stock GSR tranny with type R LSD
exhaust: custom welded 2.25" catback with ES-oval straight through muffler (2.5" in/outlet). piping is INVIDIA 2.25" with resonator
wheels:
before 3 months ago: 205/50/15 kumho SPT
since months ago: gsr blades with 205/55/15 Hankook Radial K106
O2 sensor (since 1998)
stock dual sensor gsr cat (since 1998)
stock intake manifold but port and polished internally
stock headers
maintenance:
within 2 years: new cap, rotor, fuel filter, head gasket with ARP studs, new alternator belt, timing belt, new spark plugs, new thermostat (stock setting)
tire pressure: 35psi front, 33psi rear
air filter: K&N. cleaned half a year ago. still fairly clog free.
compression check: never done this.
last tune up: haven't had one since i swapped this motor 2 years ago, i replaced most of the stuff listed above.
Old Apr 28, 2010 | 09:36 PM
NACvicSi's Avatar
Default Re: b18c1 gas mileage problem. is this normal?
What all mods have been done in the year since your mileage was normal? Have you changed your driving habits or your locations you travel to different? When was the last time you did a tune up; plugs/wires, fuel filter, cap, rotor, tire pressure, compression check, air filter, etc etc?
Old Apr 28, 2010 | 10:01 PM
tekstyle's Avatar
updated the OP.
all these mods have been done 2 years ago. before the mods, i believe i had about 24 city/27 mixed. then again, i drove mostly on flat terrains with the same driving habits.
mm96
Mar 6, 2010 09:06 AM
silverb18
Apr 24, 2005 06:31 PM
CHARD23
Feb 3, 2005 11:00 AM
_Cyclone_
Jan 6, 2005 01:08 PM
sicivic
Jun 8, 2004 08:43 PM
