weird starting issue with my d16...
Old Apr 28, 2010 | 01:53 PM
mikej94civex's Avatar
Default weird starting issue with my d16...
car is a 5sp, umm for some reason every time i go to start the car after its been sittin long enough to cool
down, it will not start the first turn over, but every time on the 2nd turn of the key?? starter problem?
Old Apr 28, 2010 | 02:10 PM
Former User's Avatar
Default Re: weird starting issue with my d16...
Is this a no-crank or a crank but no-start problem?
Old Apr 28, 2010 | 02:13 PM
4dohs4mohoes's Avatar
This question is kinda vague. When it does not start... does the engine "turn over", or nothing at all happens. If the engine is "turning over" then the starter is working. The starter is what makes the engine "turn over" when starting.
Give us a little more info... and maybe I can help.
Old Apr 28, 2010 | 02:35 PM
my bad for bein so vague(at work and was tryin to hurry lol) it's a "crank but no turn-over" i turn the key, i hear the starter click 2, or 3 times
then i turn the key back, then on again and it starts...if i hold the key for 5+ clicks it'll start but i don't like doin that..
Old Apr 28, 2010 | 02:39 PM
That's a no-crank problem if you only hear the starter solenoid click. Sounds like a starter motor problem.
Old Apr 28, 2010 | 02:55 PM
hmm, i can feel it crank tho, it's not only the solenoid i hear, but i can feel it tryin to turn...
Old Apr 28, 2010 | 04:34 PM
Originally Posted by mikej94civex
...i hear the starter click 2, or 3 times
^^^This makes it sound like you only hear the solenoid clicking without the motor turning.
Anyway, does the starter labor slowly to turn the engine or does the starter crank at full speed?
Old Apr 28, 2010 | 06:03 PM
b20hatchek's Avatar
replace the starter
Old Apr 28, 2010 | 06:24 PM
redeg666's Avatar
if there is an alarm in it, it could do it to
Old Apr 28, 2010 | 07:49 PM
wow.... okay. Dont listen to this.
Sounds like a starter... or a main power/ground connection issue.
Check all connections to the starter. If all are tight and right, replace the starter.
professorman
Mar 18, 2013 10:44 AM
battleREADYb20
Apr 30, 2009 02:36 AM
EJ1 wilcox
Apr 25, 2005 02:25 PM
Race Egr
Jan 31, 2005 01:18 PM
civicbro
Feb 19, 2004 02:47 AM
