Ignition delay on Type R swap
Old Apr 28, 2010 | 01:11 PM
zGo's Avatar
zGo
Default Ignition delay on Type R swap
When I go to start the car I notice is takes it a second to recognize what's happening. It cranks over fine just seems like the signals is delayed. It's always only been like a half second but the other day it took about 15 seconds before it recognized I was trying to start it.
All lights come on with key on but it didn't want to recognize that I turned the key.
Also would this have anything to do with me not having VTEC? It's throwing a speed sensor code but the only thing I haven't tried is the cluster, we've tried a few speed sensors/ECU/and checked all wiring but still no foul.
Car is a 93 del Sol SI with a '96 spec R b18c.
Old Apr 28, 2010 | 01:22 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Ignition delay on Type R swap
sounds like a starter may be on the way out
Old Apr 28, 2010 | 01:47 PM
Former User's Avatar
Potential bad ignition switch.
Old Apr 28, 2010 | 01:49 PM
zGo's Avatar
zGo
Is that a junkyard part or would I need to get the whole assembly around the column with new keys?
Also would that cause anything to do with the speed sensor?
Old Apr 28, 2010 | 02:08 PM
The VTEC and speed sensor are separate. What CEL codes? The VSS connector is often corroded or bad. You can try to find a replacement connector at a junk yard.
Ignition switch: You would only need to replace the electrical switch, if it is bad.
supra-n-civic
Jun 23, 2009 07:01 AM
aziaticvang
Jan 13, 2008 06:35 PM
GRANDE7652
Jun 2, 2006 05:19 AM
sir2sol
May 7, 2006 09:51 PM
PaisanITR
Mar 4, 2006 11:17 AM
