help with water pump ??? gap 90 accord ex
Old Apr 28, 2010 | 07:00 AM
youknow253's Avatar
Default help with water pump ??? gap 90 accord ex
ok the other day i pop my hood look down on the right side by the timing belt there is a gap where the water pump is off the timing belt about a half inch wide and im wondering what i should do theres no leaks (yet) : ( but i would like too know if this is regular or what the deal is???? please help
Old Apr 28, 2010 | 07:13 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: help with water pump ??? gap 90 accord ex
if I'm understanding you correctly the timing belt has shifted a 1/2in on the water pump gear, correct?
no, the belt should not be off the gear at all. riding at the edge is fine but not off.
have you tried to redo the tension on the timing belt? maybe the tension is a bit loose and the belt has walked a little. when redoing the tension, be sure to locate the belt onto the pulleys correctly and that it stays there as you rotate the engine by hand.
how many miles are on the car and when was the timing belt last serviced?
Old Apr 30, 2010 | 12:17 PM
youknow253's Avatar
its got 87k and i just changed clutch and it seems like the water pump itself is shifted away from the block were it should be up flush with it right?
Old Apr 30, 2010 | 09:01 PM
RICKSAUTOMOTIVE's Avatar
WOW! sounds strange. but i see stanger stuff now and then. either the belt walked like touring accord stated or the pulley/gear is coming off the pump and that is walking. i took a pump apart to see how it works. it took a 40 ton H-press to get it off (that was all i had). but after i seen it, i was amazed at the durrability of the bearing. it was like over 1 inch wide!! i cant imagine a timing gear on the pump walking out like that but you never know. can you post pics? i do believe its the belt most likely walking off though
car5car
Jul 9, 2017 05:41 AM
NFrank89
Oct 19, 2010 06:59 AM
globy123
Aug 8, 2008 08:38 AM
Miz101
Feb 15, 2004 07:07 PM
1998hondaaccord
Sep 18, 2003 07:25 AM
