Replica Hytech Header flange hangs TOO LOW! anyone else have this issue?
Old Apr 28, 2010 | 06:35 AM
92integraVTECgsr's Avatar
Default Replica Hytech Header flange hangs TOO LOW! anyone else have this issue?
I have a Replica Hytech Header and the collector flange that bolts up to the rest of the exhaust hangs too low. It looks like the design of the header that it just points down.
Does anyone else have this issue?
Old Apr 28, 2010 | 07:29 AM
nokturnal_munkeeboy's Avatar
Default Re: Replica Hytech Header flange hangs TOO LOW! anyone else have this issue?
show us the pics, so we see what you talking about
Old Apr 28, 2010 | 10:25 AM
RedEG2's Avatar
hytech reps are known to hang low. also where did you get the header?
Old Apr 28, 2010 | 05:08 PM
EHondaJDM's Avatar
92 integra vtec....do u have a B17 by any chance? If u do and u ordered the header for a b18 then that's y. The b16,17 has a shorter oil pan the b18 so it sits too low. likewise a b16,17 header won't clear a b18 oilpan
Old Apr 28, 2010 | 08:14 PM
keepinitrehaal's Avatar
pics will help
Old Apr 29, 2010 | 03:31 PM
I have a LS/VTEC with the B-series replica hytech small tube header that was bought from pipi-outlet on ebay. The flange itself just sit WAY too low because the bottom section is on too much of an angle pointing down.
Here are some pictures. Does anyone else have this issue?
Old Apr 29, 2010 | 07:15 PM
HondaManMike's Avatar
i have the same exact issue, i guess thats why its a replica. to make matters worse, im running a 3 inch exhaust
Old Apr 29, 2010 | 08:41 PM
RedEG2's Avatar
funny thing is the add says "best ground clearance."
Old Apr 29, 2010 | 09:50 PM
dntnedvtec's Avatar
ouch, that hurts....I just ordered a kiddracing header.....I hope I don't have the same issues...
Old Apr 29, 2010 | 09:56 PM
vtaker's Avatar
I would take it to an exhaust shop right now and have them modify it.
Old Apr 30, 2010 | 03:41 AM
S13Morgan's Avatar
I ordered and am running the RMF narrow style header and it has really good ground clearance. I absolutely love the header.
Old Apr 30, 2010 | 09:19 PM
Can you take pictures of your clearance and how low it is like I did with mine so I can see a few different angles?
I don't mind that header sit low, the flange is what bothers me. And the only way to fix that would be to cut it at the single pipe and weld it straighter, but I don't want to do it.
Old May 1, 2010 | 11:07 PM
EHondaJDM's Avatar
Take the header out and put it in a vise, heat up the pipe as far forward as u can, while its cherry take a pry bar and stick it in the outlet and bend it upward.
Id fix that quick your gonna be hurtin if that flange catches somethin.
Oh and stay away from ebay crap unless its and name brand
Old May 2, 2010 | 09:12 AM
nonsense's Avatar
So you bought a cheap Chinese knockoff and it doesn't fit perfectly like the real header?
Old May 2, 2010 | 09:30 AM
EHondaJDM's Avatar
Damn, That's low, no need to rub it in on the kid.
Old May 2, 2010 | 09:59 AM
I sure did. And I will keep buying them.
Old May 2, 2010 | 05:09 PM
nonsense's Avatar
I don't care if you do, just don't complain that a POS fits like a POS.
Old May 2, 2010 | 05:19 PM
bluebomber's Avatar
Information Leafblower
...Replica...
Well there's your problem right there.
Old May 2, 2010 | 09:02 PM
I'm just wanting to know if any others had this problem or not. Trying to find out if it is a defect/flaw if so, I'll just buy another one..
I'm thinking about the RMF one. But whats to say the real ones are any different?
Old May 2, 2010 | 09:56 PM
bluebomber's Avatar
Because I have an authentic Hytech header and can tell you firsthand that the fitment is spot-on perfect. You definitely get what you pay for, and quality with proper R&D is rarely cheap.
Old May 18, 2010 | 11:27 AM
southernSCHEME's Avatar
sorry to bump this thread but i got the same exact problem with this header.
OP, were you able to find a solution? i really dont wanna raise my car up
Old May 18, 2010 | 04:25 PM
any1???
Old May 18, 2010 | 04:26 PM
bluebomber's Avatar
Raise your car, or buy a real header. Those are your options.
Old May 28, 2010 | 07:47 PM
rayzian's Avatar
i just installed this header (93 DB1), i cut off my cat to get it to fit to find out the flange sits literally 1cm off the ground... i couldn't get my rad support back on either... just by having someone sit in the car it touches the ground.. the flange scrapped hard just moving it out of the garage.. i don't know if i want to sacrifice this ground clearance for the power gain... god damn the header looks sweet though
Krayzielix
18
May 31, 2011 02:58 PM
GenIIIMrDuece
Mar 21, 2008 08:17 AM
PPLH8R
Welding / Fabrication
14
Jan 20, 2008 11:58 AM
neo_
Nov 1, 2006 04:28 PM
Driven
May 23, 2006 06:43 AM
