maintenance required
Old Apr 27, 2010 | 10:06 AM
jagumbel's Avatar
Default maintenance required
I recently ran a can of Sea Foam through my gas tank and now my maintenance required light comes on...
Anyone know why or how i can turn it off? Is it running in limp mode now?
Old Apr 27, 2010 | 10:23 AM
turboteg2nv's Avatar
Default Re: maintenance required
Did you change your oil after using seafoam? Because you're supposed to. Plugs wouldn't be a bad idea, either.
Old Apr 27, 2010 | 11:01 AM
aspire's Avatar
its in the honda manual on how to do it. its some clicking stuff. I don't remember.
&I've heard the light goes on to certain mileage, like timing. But that's only what I heard.
Old Apr 27, 2010 | 11:02 AM
aspire's Avatar
Sorry, also, I will check for you when I get home if no one replies by then.
Old Apr 27, 2010 | 01:41 PM
charleso's Avatar
1. Turn off engine
2. Press and hold the Select/Reset button on the instrument panel, then turn the ignition switch to ON.
3. Hold the button until the indicator resets (approximately 10 seconds).
Old May 3, 2010 | 06:23 AM
Beer's Avatar
Turn the key on while holding the trip button down for >6 seconds
Old May 4, 2010 | 02:21 PM
makavelibranded4's Avatar
the maintenance required light is a oil change reminder nothing more, limp mode you wouldint be able to rev past 4k
Old May 12, 2010 | 10:57 PM
03_NBP_K20A2's Avatar
turn your key on the on position w/o starting. Press and hold your odometer button for 10 seconds and start your car. It's a oil change reminder light and starts coming on after 7500 miles and stays on after 10,000 miles.
jhavnews
Sep 3, 2018 01:26 PM
Aponcebmx
Apr 2, 2010 05:59 AM
caseyjholmes
Honda S2000
Apr 30, 2007 10:20 AM
hookedonvtec
Jul 20, 2004 08:22 AM
Joker
Dec 30, 2002 01:26 PM
