88-89/90-91 Dash differences
Old Apr 27, 2010 | 06:42 AM
4g4dcruisin's Avatar
Default 88-89/90-91 Dash differences
Besides the obvious random button/switch differences. Is there a size difference? Or over all shape difference?
The reason im asking is because my 90-91 needs a dash, and the one i have access to (its for free and in good shape) is from an 88-89. Help is appreciated.
Old Apr 27, 2010 | 06:53 AM
blasterman87's Avatar
Default Re: 88-89/90-91 Dash differences
same dash from what i can tell, i have a 91 im putting in my 89
Old Apr 27, 2010 | 06:56 AM
I cant remember which button is diferent on the 88-90 than on the 90-91, but its on the left side of the center air vent. I need it to match up with the steering column cover also.
Old Apr 27, 2010 | 07:08 AM
crx_si-r's Avatar
cluster covers are different so those might need to be swapped out, im not sure if you can use your 90-91 style cover on your new 88-89 dash. i know the dash harnesses are different as well, buy you can get away with swapping yours into the new dash. aside from the cluster cover you should be ok.
Old Apr 27, 2010 | 07:13 AM
I'll just use the 88-89 cluster cover. I've put a hatch dash into a sedan before and i used my sedan wire harness so i know what you mean regarding that.
Old Apr 27, 2010 | 09:29 AM
Clipsed's Avatar
Can't swap cluster covers on the sedan dashes, so you will need to use the 88/89 cluster as well as the wiring, and rewire it to wirk properly.
Old Apr 27, 2010 | 09:33 AM
Yea, see this **** aint gonna work. I'll just have to get a 90-91 dash from pick a part.
Old Apr 27, 2010 | 03:00 PM
BiG ChOr!Zo's Avatar
i have my 91 ed3 dash if you dont mind broken corner pieces...other than that the main parts are bueno...!!!
Old Apr 27, 2010 | 03:02 PM
KINGVEM^^ED6's Avatar
there you go whats going on with the sedan now?
Old Apr 27, 2010 | 03:21 PM
I know you mentioned this to me yesterday, but what pieces are broken? You cant even see in the pic. By the "corner pieces", im thinking of the two removable panels on each side to access the side bolt when you remove the dash from the car. I can care less about those.
It doesnt matter if anything is really "broken", i'll proabably be doing a interior dye depending on if i can find black sedan carpet like my last sedan.
If not, i'll just leave all stock blue, i MIGHT be just gutting this car completely, only leaving a dash, driver/passenger seats, and thats it.
Eric, i think im gonna have to come over there friday evening. Sorry man, but i dont have the time after work the rest of this week to make a trip. If you sell it before then, cool, if not, i'll be there.
Old Apr 27, 2010 | 03:26 PM
Going to turn it into a full project, not going to insure it. Once i get everything in order, i'll be completely stripping everything (in the interior and engine bay), and rebuilding starting with the hissing tranny. So a throwout bearing or input shaft bearing is in order.
I have my engine hoist, so i'll just leave the motor hanging there until i can;
a. Get some quality pistons/rings (block in the car now has 314xxx!!)
b. Find another a6 block, or possibly zc in KNOWN, low(er) miles.
Other than that, the car needs nothing mechanically. I'll be adding sidemarkers of course, and my pin striping eventually.
I WILL NOT BE PAINTING THIS CAR, haha. I'm gonna leave it as is until i find a white hood and trunk.
im not gonna sell it since i just made the exception of letting it go to you instead...this friday evening is a not good since ill be leaving to los angeles that day...anytime from tonight until friday afternoon is fine for me...i have most of the little pieces that broke off and a little crazy glue should do the trick...!!!
Old Apr 27, 2010 | 03:28 PM
Alright, fair enough. I'll be able to shoot out there either wed, thurs for sure. Thanks for the trade, its about time i got another sedan haha.
Oh, i'll post pics of the two sedans tonight, maybe ill start my own build thread.
Old Apr 27, 2010 | 03:29 PM
i think i need to find me a $100 sedan also so that i could transfer some parts to mine...im tired of paying junk yard prices and i still have no luck finding a non-ripped black carpet for mines also
Old Apr 28, 2010 | 06:17 AM
Here are pics of both my sedans. $900 total. Im not parting out either one, im going to be turning the 88lx into my DD, besides my Jetta. The 91ex is going to be strictly a project.
EE2bitsk
Jun 18, 2010 08:15 AM
BSeriesRescueteam
May 7, 2009 10:29 AM
sasinorm01
Jul 21, 2008 07:57 AM
julioboostamante
Dec 7, 2007 04:57 PM
dem0nk1d
Jul 12, 2007 05:49 AM
