Need a new key for '96 Odyssey/Shuttle
Just purchased a '96 Honda Shuttle (Odyssey) and we need another key but it has a chip. It is the UK version of the Odyssey but seems to be the exact same thing. Does anyone have a contact to get a new key? I have and can provide all the information needed. I checked locally and it's ridiculous.
TIA
TIA
Thanks guys. I'm looking at 200 Euro which is approximately $265 and I'm needing two because the one that I have is jacked.
I'll start looking around for an ECU too which doesn't sound like a bad idea. I just want to make sure that it has the same restrictions, U.S. vs U.K. model.
If you look around( it was removed from this site) there is a write up on how to remove the disabling device from the ecu. If it is removed the car runs fine but the ecu light on the dash stays on. There is some kind of resistor or diode you can solder in place if it to remove the light. Do a search I'm sure it's around
DelSol-B18
15
Apr 7, 2014 06:36 AM
