how do you convert obd1 90 integra??
Old Apr 26, 2010 | 11:11 PM
skromee's Avatar
Default how do you convert obd1 90 integra??
hi i want to know what list of parts i need to do a obd0 to obd1 conversion on my 90 integra
Old Apr 27, 2010 | 01:36 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: how do you convert obd1 90 integra??
Are you converting the B18A or swapping in something different? If you are converting the B18A you will need:
1. 92-95 OBD1 ECU (P74/P75) with an OBD0-1 jumper harness
2. 92-95 OBD1 B18A/B Distributor (use with distributor adaptor or repin your current plug)
3. You can reuse your current injectors or use the OBD1 injectors but you'll have to delete the resistor box and solder the OBD1 connectors on it
4. Wire up 3 additional wires for the 4 wire O2 sensor and use a OBD1/2 bseries exhaust manifold for the correct placement of the O2 sensor or weld in an O2 bung before the cat on your current manifold
Dkahn18
Feb 18, 2009 04:41 PM
CraiGlOl
Feb 7, 2009 03:03 PM
hi-Powered
Apr 30, 2005 01:28 PM
EFing8
11
Dec 15, 2002 09:08 AM
7rrivera7
Nov 9, 2002 06:38 AM
