Transmission Fluid Help
Old Apr 26, 2010 | 08:45 PM
JDM_WHR's Avatar
Icon2 Transmission Fluid Help
I have a 94 civic DX 1.5 and need to change my transmission fluid, anyone know what weight and what brand is best?
Old Apr 26, 2010 | 09:05 PM
Hill4589's Avatar
Default Re: Transmission Fluid Help
Assuming you have a manual transmission, Honda MTF is best.
Old Apr 27, 2010 | 05:34 AM
JDM_WHR's Avatar
yea i do
Old Apr 27, 2010 | 06:01 AM
macson's Avatar
Can't go wrong with Honda MTF. About to put Torco MTF in mine tonight though, I'll let ya know how it runs.
Old Apr 27, 2010 | 06:37 AM
97twodoor's Avatar
Honda MTF is the best, as it was designed for Honda transmissions.
Old Apr 27, 2010 | 06:39 AM
Jockone's Avatar
Honda MTF it's all I use.
Old Apr 27, 2010 | 06:43 AM
JDM_WHR's Avatar
buy at the auto stores or @ Honda dealerships?
Old Apr 27, 2010 | 07:00 AM
macson's Avatar
I go to the dealership.
Old Apr 27, 2010 | 07:05 AM
96hb's Avatar
Just put whatever you like in there. I'm sure that Honda mtf is the best, but you can run motor oil in there as well. I changed mine out a couple years ago with some Mobil 1 synthetic 0w30 I had laying around. Shifting has been just as smooth and silky as ever. Besides, it's just a d-series.
Old Apr 27, 2010 | 07:45 AM
98VicEX's Avatar
you can't just run motor oil in ur tranny there are special additives in it. you should always use the recommended fluid which should be in the owners manual and if not easily looked up online
Old Apr 27, 2010 | 08:15 AM
JDM_WHR's Avatar
how many bottles do i need?
Old Apr 27, 2010 | 08:20 AM
ChokolAwt's Avatar
OVER 9000 to go with your turbo timer and 9" tach.
you'll need 2qt's honda MTF which will cost you roughly $20.
Old Apr 27, 2010 | 08:50 AM
macson's Avatar
You can. It states it directly in said manual. Albeit it stating that you can if MTF isn't available, it's not going to harm anything in the short-mid term.
Old Apr 27, 2010 | 09:01 AM
96hb's Avatar
Well, I do and my car is going on 220k miles, so...
Old Apr 27, 2010 | 04:15 PM
Cynical 1's Avatar
yes, owner and service manual states 10w40 motor oil is acceptable for the manual transmission.
i'm running mobil 1 10w40 synthetic in mine, and have in other hondas in the past with no issues.
Old Apr 27, 2010 | 04:23 PM
ThatGuy522's Avatar
put in some GM syncromesh it is some really good stuff...i know that even euro guys are using it to get rid of grinding into gears and stuff like that...its like shifting through butter
Old Apr 28, 2010 | 05:51 AM
macson's Avatar
Had a night of driving with the Torco MTF in my y8 trans, seems like it's some good stuff. No issues.
Old Apr 28, 2010 | 04:40 PM
titosek4's Avatar
Anyone have exprience Lucas transmission fluid stabilizer,I have some left over and wondering if it would do any harm to my ls tranny. Ran fine I'm my old ex auto but I know manual trannys are different
Old Apr 28, 2010 | 04:56 PM
BryanM.'s Avatar
Resident Gearhead
I HIGHLY doubt that will do anything for MTF.
Also I must add that I have used 10w30 in my transmissions for years and recently switched to Honda MTF. I have noticed smoother shifting but nothing incredible.
We'll see if the magnet picks up more or less steel with the Honda MTF:
Magnetic transmission oil drain plugs are worth using. ( 1 2)
Old Apr 28, 2010 | 11:20 PM
saltybeagle's Avatar
Ive always used honda MTF however i have some royal purple syncromax that is supposed to do wonders. If you have grindage issues use the synthetic stuff. Otherwise use H MTF.
Old Apr 29, 2010 | 09:56 PM
JDM_WHR's Avatar
what weight should i use? 10w-30, 10w-40, etc?
Old Apr 30, 2010 | 01:25 AM
EcivicG's Avatar
First time i changed it i put in royal purple synchromesh, but after that it felt as if i lost acceleration because of how thick it was and my tranny was grinding in almost every gear. i had to baby the **** out of it.
so after that i dropped the purple and threw 2 qt's of mobil 1 syn10w30 and it shifts like butter.
Old Apr 30, 2010 | 03:04 AM
BryanM.'s Avatar
Resident Gearhead
I believe the Civic Owner's Manual say 10w30.
I would give the Honda MTF a shot, it's not too expensive.
Old Apr 30, 2010 | 07:29 AM
JDM_WHR's Avatar
i got Royal Purple 10w-30, HOPEFULLY it works well!
Old Apr 30, 2010 | 07:30 AM
97twodoor's Avatar
Should have got Honda MTF. It would have worked much better.
