Preferably never built before, bare is ok as long as original caps are in place.
i have a bare long block jdm b20b if ur interested.. the threading needs to be filled and rethreaded to bolt the driver mount to the block. asking 300 for it if ur interested
No thanks on this.
Originally Posted by MOE@Hyper16Valve
I have a short block it's the higher comp type just needs some crank work,No spun bearings just needs a polish,Rods have Brand new OEM ROD BOLTS,also have brand new gsr timing belt and water pump NOT oem BUT brand new...
I need to make sure it's a JDM block, do you have a picture of the stamp? B20B or B20B1/Z1?
