FS: WW Side Skirt/JDMSh!t Lip, Eagle Rods, CRX/DA Junk
I have accumulated a lot of junk that I need to get rid of, if parts towards the end of the thread are not sold within so long they are going into the dumpster.
koni yellows and neuspeed race springs off 92-95 hatch. upgraded to the gc/koni setup so no need for these. will fit ek with washer mod. gives a nice drop 2.2" front/2.0" rear. struts/springs have less than 5,000 miles on them.
$400 for locals
$450 shipped/paypaled.
Muckman Stainless Steel braided line for wastegate - $25
JDMsh!t Polyurethane Mugen replica front lip & Wings West sideskirts w/ hardware. Front lip has a few scratches on the underside, but not noticeable once lip is on the car. Lip has not been painted. Wing's West sideskirts were bought used. I sanded and repainted them with SEM Trim Paint ($20 a can). Comes with original hardware from Wings West. Bumper not included.
Lip: $150 obo
Side Skirts: $225 obo
Sold together: $325
Eagle Rods w/ upgraded arp bolts for GSR - bought used with approx. 1000 miles, however, sold my gsr, so no need for these now.
Eagle Rods: $200
Cometic Head Gasket for B18B. 81mm .075". Received the wrong gasket, was unable to return. Good for guys with high compression motors who want to go forced induction.
Cometic Head Gasket: $70
90 degree bend for 38mm wastegate - Used on my manifold before the wastegate placement was corrected, comes with hardware.
90 degree bend: $30
Ebay clear corners for 92-95 Civic. Came with my current car, traded out for stanleys. Insides of corners still need to be cleaned.
Corners: $20 (will not separate)
Two LS Motors with spun rod bearings. Only good for rebuild. Both of them came from a car I purchased, but now I need room so these must go.
1. B18B – 250 obo (still need to take apart to see damage)
2. B18A – 150 obo (bearing spun on #3, mains still in good condition, crank may be salvagable, but more than likely easier to replace. ) can pm pictures of damage. will throw in a pre-obd distributor for $50
Pre-OBD PR4 ECU: $50
1. DA Front Spindles (Calipers/Rotors included) – SOLD
2. DA Upper Control Arms - $5 each
3. DA Front OEM Struts/Springs - $5 each
4. 2 Power Steering Pumps (pulley uses 1 row belt) - $5 each
5. DA Manual Pedals - $5
6. DA Master Cylinder/Booster – $10
7. DA Front Lower Control Arms - SOLD
8. Radiator Hoses - $5 for all
9. DA Flywheel - $10
10. Pressure Plate/Clutch (used/pressure plate has surface rust) - $5 each
11. Da Upper exhaust manifold w/ O2 sensor - $5
12. Starters (need rebuild) - $5
PreOBD Da Engine Harness - $50
PreOBD DA Chassis Harness (missing a few connectors that go into engine bay) - $50 ($25 if purchasing the engine harness)
1. CRX Radiator - $5
2. AC System for CRX (not sure if all lines are there, but have a few) compressor/mount/harness/fan/all seen included - $40
3. Fluid Reservoir for CRX - $5
4. 3 of 4 Mud Gaurds for CRX (front passenger has crack) - SOLD
5. Exhaust hanger for CRX - $5
6. Lower Exhaust Manifold/Cat/Heatshield for CRX HF - $5
1. CRX Battery Tray - $5
2. CRX HF Shift Linkage - $5
3. CRX HF Spindles - $10 each (comes with new brakepads in box)
4. CRX HF Axles - $5 each
5. Battery/Starter Engine Cable - $5
6. Underdash Gauge Cluster Harness - $5
1. CRX Passenger Headlight w/ driver side bracket - $5
2. CRX Center Tail Light - $20
3. CRX Glove Compartment - $5
4. Radiator Stays and a Clutch Cable Bracket - $5 each
5. CRX Rear Trunk Compartment Light - $5
6. CRX Rear Speaker Mounts – $5
7. CRX Center Console - $5
8. CRX Panels - $5
9. CRX Panels - $5
10. CRX Panels - $5
11. CRX Panels - $5
12. CRX (DX? 88-89) Gauge Cluster - $20
13. DA Gauge Cluster - $20
1. $5
2. $5
3. CRX Coin Pocket - $5
4. B Series AC Compressor (unsure of condition) came off an old LS motor - $10
5. DA Mirrors - $5 each
6. DA Rear View Mirror - $5
1. CRX Clutch Cable - $5
2. CRX Throttle Body Cable - $5
3. DA Throttle Body Cable (missing one tab to hold to firewall) - $5
1. Power Steering Pump Mount - $5
2. AC Mount - $15
3. AC Mount - $15
4. Transmission Torque Mount - $15
5. Transmission Torque Mount - $15
6. D Series Rear Engine Mount - $5
7. $5
8. $5
9. $5
10. $5
11. $5
98 Civic Driverside Airbag - $15
2 12" 1200 Watt Sony Xplods w/ box – $75 obo
Parts SOLD:
DA Front Spindles (Calipers/Rotors included) – $20
DA Front Lower Control Arms – Went with DA Front Spindles
3 of 4 Mud Gaurds for CRX (front passenger has crack) - $5 each (all for $10)
Blue CRX Cargo Cover (2 pieces) - $10
CRX Tire Cover - $10
$400 for locals
Lip: $150 obo
Sold together: $325
Eagle Rods: $200
90 degree bend: $30
8. CRX Panels - $5
9. CRX Panels - $5
10. CRX Panels - $5
11. CRX Panels - $5
1. $5
2. $5
2. AC Mount - $15
3. AC Mount - $15
7. $5
8. $5
9. $5
10. $5
11. $5
Parts SOLD:
