ep3 civic si cluster into a 91 civic si. help
has any one done this or is thinking of doing this, i need info. i like the aber lighting at night and my cluster is bad so might as well swap it. thanks
Good luck! I just installed a EM2 cluster which is basically the same thing. You will have to get like an autometer temp gauge cause there is no wiring for it. I am still working on the gas guage situation because it doesn't read properly, I think the ohms are different for the sending unit. The cel light is on constantly even when there is no cel. I just put mine in last weekend so I am still working out the bugs.
Here it is installed.
Here is a pic of mine when you turn the car on.
And when you turn the lights on.
wow that looks gr8 thanks. can you show more pics of the cluster with out the top, and what do you mean by the cutoff wheel.
kizner
Dec 30, 2005 05:44 PM
babyviper97
Jan 8, 2003 04:23 PM
djmatix
Aug 17, 2002 12:38 PM
