Crx dash w/ hatch cluster prob, and blinker problem
Old Apr 26, 2010 | 08:33 AM
Choy's Avatar
Default Crx dash w/ hatch cluster prob, and blinker problem
So i just finished putting a crx dash into my hatch, and have found out that either the cluster does not fit without fab, or im doing it wrong. along with the cover.
and my next question is, my blinkers arent really working right, and they will do the left turn signal fine, but the right one isnt working at all, how should i go about testing/fixing/ whatever to make this work?
Old Apr 27, 2010 | 12:30 PM
Choy's Avatar
Default Re: Crx dash w/ hatch cluster prob, and blinker problem
bump
Old Apr 27, 2010 | 04:29 PM
bmanuhutu's Avatar
I also had the CRX dashboad installed in my hatch, everything was fine.
Your cluster wont fit, probably you using civic hatch cluster metal holder, am i right? If so you need to replace the cluster holder with the crx metal cluster holder.
And the turn signal, you may need tester to check what you did wrong.Mine everything worked fine.
Old Apr 27, 2010 | 04:57 PM
MrToxygen's Avatar
hey fellas on the console bracing is there holes under the carpet for the support bracket or did you just drill holes there? Ive got all of mine done cept the cluster cover and the support piece...
Old Apr 27, 2010 | 07:41 PM
Choy's Avatar
my brace is just there, took the bottom brackets off though
Old May 9, 2010 | 05:10 PM
Choy's Avatar
bump, i still dont understand why it wont fit, dont mind the blinker question.
H22BB6
Aug 27, 2012 08:47 AM
crex23
May 17, 2009 04:06 PM
sothasom9
Sep 5, 2008 10:57 PM
acydphryck
14
Jul 25, 2003 12:00 PM
