CTR Cams in a GSR
Old Apr 25, 2010 | 08:59 PM
litoekneeil's Avatar
Default CTR Cams in a GSR
Hey everyone
I was wondering how would the engine be like after putting ctr cams into a 98 gsr motor? Would it idle properly without a tune? How much harder would vtec kick?
Any input would be greater appreciated.
Old Apr 26, 2010 | 06:38 AM
Default Re: CTR Cams in a GSR
anyone
Old Apr 26, 2010 | 06:52 AM
300whpej's Avatar
will idle without a tune, vtec will be pretty aggressive and would be a step up from the gsr cams, but a step under most stage 2 cams. without a tune, you will **** through gas if you like da vtakz
Old Apr 27, 2010 | 01:18 AM
kulo's Avatar
im got ek9 cams in my gsr
runs good
just needs tuning
running on chipped ecu with gsr/itr map
Old Apr 27, 2010 | 04:49 AM
evildc2's Avatar
Just make sure to upgrade your exhaust side valve springs with inner springs, other then that you should be fine.........it wouldnt hurt to tune it
99ekb18b
Sep 12, 2008 08:55 PM
Easyslider01
May 6, 2005 10:11 AM
flat-blk-HB
Jan 28, 2005 03:38 PM
yanasaki
Aug 5, 2003 11:31 PM
IgniteTeg
May 19, 2002 12:23 AM
