OBD0 to OBD1 CELs 9 and 20
Hello all, I've having a problem with my conversion. I'm receiving the follow error codes 9 = No 1 Cylinder Position CYP Sensor and 20 = Electrical Load Detector ELD CELs) after converting.
Let me give some background info first: Its a ef crx hf, the original engine died, so I swapped it out for a 1st gen JDM B16A with a PW0 ECU. The car has been running great for year. The reason behind the conversion is I want to boost the motor, hence the conversion.
So the following were bought:
JDM P30 ECU
Conversion Harness
OBD1 Distributor w/OBD0 plugs.
Conversion was done,car starts and it appears to be running fine. The only think that i getting are those CELs. Did some research on those codes and they appear to be Distributor related. I've check the wiring on the harness connector and the distributor connector and they are as follows:
OBD0 Harness Connector - OBD1 Distributor Connector
White - Yellow/Green
White/Orange - Beige
White - White
Orange/Blue - Beige/Blue
White/Blue - White/Blue
Blue/Green - Blue/Yellow
Blue/Yellow - Blue
Tried a different Dizzy and the same errors appeared. So what do you think??? Thanks in advance.
JDM P30 ECU
Conversion Harness
White - White
Blue/Yellow - Blue
JDM P30 ECU
Conversion Harness
White - White
Blue/Yellow - Blue
JDM P30 ECU
Conversion Harness
White - White
Blue/Yellow - Blue
Paul26
24
Oct 14, 2012 01:29 PM
