FS:Best Upgrade all EG Hatchback Owners Should Do
Old Apr 25, 2010 | 06:37 PM
ShiroX's Avatar
Default FS:Best Upgrade all EG/EK Hatchback Owners Should Do
Services no longer available.
Power Windows and Power Door Locks!!!
I am selling Plug and Play wiring solution
for non-power Honda Civics
Using Twistedimage's How-to:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-95-civic-power-door-conversion-right-way-tons-pics-end-all-swap-2337026/
Detailed Photos of harness rebuild
I am selling a Plug and Play Power Conversion Harness for
1992-2000 EG/EH/EJ/EK Civic.
NEW* I CAN NOW MAKE HARNESS FOR 1996 -2000
EJ/EK Civic Hatch/Coupe!*NEW!
*see pictures below*
This harness makes converting to Power an absolute breeze.
If you can plug in a connector...you can install this harness.
All the connectors have been inspected and cleaned. Any old tape has
been removed and re-taped. All brand new 1/4", 3/8" and 1/2" wire loom.
All connections if necessary were soldered and heat shrinked.
NO BUTT/CRIMP CONNECTIONS!!!!
Everything is 100% clean and looks OEM.
Parts included:
Passenger Harness
Driver Harness
OEM Denso Power Window Relay
x3 20A Fuses
$125 plus shipping
Paypal add 3%
Extras I can do:
*Re-Pinned for door lock alarm hookup into cabin through factory harness
*Re-Pinned for power window DEI 530T alarm hook up into cabin through factory harness
*Re-Pinned for Power Folding Mirrors
Passenger Harness
Driver Harness
Connection pigtail
Complete Door to Door Harness w/ Relay and fuses
*Note Harness Pictured has extra output for alarm wiring into cabin.
New Pictures of Alarm Output to Cabin:
This is the Driver Power Door Harness:
The big grey connector is where all the alarm wiring has been integrated
into the stock power driver door harness. All the wires can be re-pinned
to stock so there is NO SPLICING OR HACKING of the stock harness.
This is the modded Interior Cabin Harness with alarm out put for window
and door lock control:
Blue plug adds 10 wires from door harness into the car cabin....8 wires
are the for the DEI 530t window control module and 2 wires are for
Door Lock/Unlock
All you have to do is connect the alarm outputs to the blue plug then
plug it into the harness.
*note this is my personal harness.
I CAN WIRE FOR JDM POWER FOLDING MIRRORS PLUG AND PLAY.
Jeff, the customer, wanted FULL POWER plus Power Folding Mirrors.
This harness has Power Windows, Power Door Locks, Power Mirrors, and Power Folding Mirrors.
All Plug and Play with OEM Honda Connectors.
Driver Cabin Harness to Fuse Box, PFM Relay, Mirror Switch, and Passenger Cabin harness.
Full Power Driver Door Harness
Full Harness Build Pictures!!
Full Power Harness Plus PFM
*NEW* 2000 Civic DX Power Window Harness *NEW*
Note: This interior harness is of a two piece design and
due to customer request, this will run under dash behind
the carpet, making installation much easier.
Factory wiring in 96-00 is one piece and runs from driver
kick panel down door sill under seat over hump under
seat up passenger sill and up passenger kick panel.
To install many more components must be removed
( door sill, carpet, seats, center console)
Driver Door Power Harness
Passenger Door Harness
Passenger Cabin Harness
*****PM for extra wiring prices.*****
Old Apr 26, 2010 | 05:25 AM
ShiroX's Avatar
Default Re: FS:Best Upgrade all EG Hatchback Owners Should Do
PLUG AND PLAY 4 PIECE POWER FOLDING MIRROR HARNESS
Another Power Mirror plus Folding Option Harness....FULL PLUG AND PLAY!
Ricardo, the customer, wanted just full power mirrors with folding option wired.
Passenger Door Harness to Power Mirror
Passenger Interior Harness To Driver Cabin Harness
Driver Cabin Harness to Fuse Box, Mirror Switch, PFM Relay
Driver Door Harness to Mirror
FULL DETAILED BUILD PICTURES:
http://www.flickr.com/photos/theratp...7624009004866/
Dave T. SUPER HARNESS Power windows Power locks Power Mirrors with Folding Option DEI 530T Alarm Window Control and Alarm Power Lock Control SUPER HARNESS
http://www.flickr.com/photos/theratp...7624212403320/
KRIS POWER WINDOW POWER DOOR LOCK HARNESS
http://www.flickr.com/photos/theratp...7624133828939/
Old Apr 26, 2010 | 08:51 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
These look really thorough and well done. Having removed power window/mirror harnesses before from vehicles before and knowing how much work is involved, I would say that your asking price is just about right.
Good thinking adding the cabin power lock connector for the alarm (Canadian vehicles already have this) and the power window alarm connection. Have you thought about building a harness that is pre-wired for power folding mirrors, too? There's plenty of tuner geeks who like this bling. I designed a nice wiring diagram in my Power Folding Heated Mirror/Window/Locks write-up (link in signature).
GLWS.
Old Apr 26, 2010 | 08:58 AM
ShiroX's Avatar
Adding the wiring for folding/heated mirrors shouldn't be a problem. I've actually read your entire write up before and you are extremely detailed and thorough yourself.
Running wires for the Alarm outputs has taken all the extra pins. I needed to add 10 wires....so it would most likely be one or the other.
The problem is finding donor harnesses to do the work ...lol
Its a PITA to remove those things when the main harness is still in the car and everything is intact. If you look at some of my pictures.. I literally had to take apart everything under the dash.
Old Apr 26, 2010 | 01:25 PM
ShiroX's Avatar
ttt
Old Apr 26, 2010 | 04:16 PM
ShiroX's Avatar
bump
Old Apr 26, 2010 | 05:00 PM
fv8s's Avatar
very nice
Old Apr 27, 2010 | 05:43 AM
ShiroX's Avatar
Thanks for the bumP!
Old Apr 27, 2010 | 03:18 PM
ShiroX's Avatar
bump
Old Apr 27, 2010 | 08:45 PM
ShiroX's Avatar
bump
Old Apr 28, 2010 | 05:16 AM
ShiroX's Avatar
bump!
Old Apr 28, 2010 | 06:04 AM
K20egcw's Avatar
You did an excellent job with that! If I ever convert to power doors (not sure if I want the extra weight) ill definitely pic a set up from you
Old Apr 28, 2010 | 06:05 AM
eh vtec sc's Avatar
how much for this shipped to AZ? 85710 lmk thanks
Old Apr 28, 2010 | 08:59 AM
ShiroX's Avatar
ttt
Old Apr 28, 2010 | 02:23 PM
ShiroX's Avatar
ttt
Old Apr 28, 2010 | 03:29 PM
red01teg's Avatar
Nice title. Made me look and I don't have a hatch lol. GLWS
Old Apr 28, 2010 | 06:06 PM
maxboost10's Avatar
good stuff. I did the conversion and it's very nice to cruise around with windows down.
Old Apr 28, 2010 | 07:45 PM
ShiroX's Avatar
Yea it stinks when you're cruising on the highway and you cant open the passenger side....well you can but it get dangerous!
Old Apr 28, 2010 | 08:07 PM
95ProjectEJ1's Avatar
TTT
Old Apr 29, 2010 | 04:56 AM
ShiroX's Avatar
thanks for the bumps!
Old Apr 29, 2010 | 08:42 AM
ShiroX's Avatar
Bump
Old Apr 29, 2010 | 01:15 PM
ShiroX's Avatar
BUMP!
Old Apr 29, 2010 | 07:46 PM
ShiroX's Avatar
bump!
Old Apr 29, 2010 | 09:33 PM
ShiroX's Avatar
bump for new pictures
Old Apr 30, 2010 | 05:54 AM
ShiroX's Avatar
bump
