93 accord clutch issue
Old Apr 25, 2010 | 02:17 PM
Johnst185's Avatar
Default 93 accord clutch issue
my 93 accord has a leaking something to do with the clutch about once a week i have to fill the resivor. i havent had time to look into it so any comon leaks would be great thank you
Old Apr 28, 2010 | 05:47 PM
fleetw00d's Avatar
Default Re: 93 accord clutch issue
Two common leaks:
1. Slave cylinder on the front of the transmission. If it is leaking, replace it. Then bleed the system.
2. Master cylinder leaking along the actuation rod. From inside the car, check where the push rod goes through the firewall, there may be a trail of fluid down into/under the carpet padding. If it is leaking replace the master cylinder. Then bleed the system.
Old Apr 29, 2010 | 06:47 PM
Johnst185's Avatar
Its alco grabbing at random places. Like one time it will grab right off the floor then right at the top. There is no happy medium with the thing. Ill chech the places said above. Thanks for the help.
axelknight
Mar 22, 2018 05:46 PM
sethnelson91
May 25, 2011 07:10 AM
hondadriver
Nov 5, 2008 06:42 AM
jonnycord
Oct 6, 2004 07:16 AM
