d16y7 to d16y8 help
Old Apr 25, 2010 | 02:05 PM
knightsef-eg's Avatar
Default d16y7 to d16y8 help
i just swapped a d16y8 in my 97 civic cx ...
i searched for awhile but cant get any good answers
can i use the y8 harness or keep the y7 ?
can anyone tell me why
i going to use the y7 throttle body for the iacv
i made a block off plate at work for the y8 iacv on the back of the manifold
i can get a 93 d15b7 iacv from a civic lx can the be modded to fit so i can use the y8 intake manifold with the y8 throttle body thanks
Old Apr 25, 2010 | 06:28 PM
Default Re: d16y7 to d16y8 help
anyone?
Old Apr 25, 2010 | 06:49 PM
92civlude's Avatar
The Y8 ECU manual trans uses a 2 wire IAC. Your best bet is use the Y8 harness and Y8 IAC. If you use the Y7 harness, Youll need to pull a wire terminal from the ECU connector and clip it into another. Youll also eliminate the ground for the 3 wire IAC. The Y8 5spd ECU wont command a 3 wire IAC.
Old Apr 25, 2010 | 07:07 PM
ok perfect...
ill use the y8 throttle body and harness
but the thing is the y8 swap i got didn't come with the iacv.. but i can get one from a d15b7 .. will it work?
Old Apr 25, 2010 | 07:35 PM
92civlude's Avatar
If it bolts up, if the coolant hoses point in the right direction, Yes.
freddy chavez
14
May 30, 2013 08:55 PM
uindaway
Nov 12, 2012 01:25 AM
jdmeg6r13s
Jul 30, 2010 08:52 AM
SOHC_civic_si
May 4, 2008 08:50 PM
SPOON_BeIgHtEeNsEe
Jan 21, 2003 06:50 AM
