Head gasket problem
Old Apr 25, 2010 | 10:07 AM
anthony g's Avatar
Default Head gasket problem
I currently own a 94 civic with a d15b vtec engine. I recently blew 2 head gaskets in the space of two days. Any suggestions on what could be the cause of this. Any help would be greatly appreciated.
Old Apr 25, 2010 | 10:09 AM
nothing_shocking's Avatar
Default Re: Head gasket problem
Not cleaning out the bolt hole good enough, not torquing bolts right, not re-torquing after a couple heat soaks, junk head gaskets.
Old Apr 25, 2010 | 10:51 AM
RICKSAUTOMOTIVE's Avatar
probably you have a warped head or deck. did you get a valve job or take the head to the machine shop to be inspected? this is a must when ever you do the valve job. also replace the head bolts too. this is recommended when you buy the gasket for a reason. they do stretch sometimes. better safe than sorry. also i personally recommend dealer head gaskets. yes i know they are a whole 30 bucks more but i sleep better and my cars run for a fey years before i have to do them again...if i ever do. and of course what nothing shocking said is also true. as is the torque wrench you used. was the torque wrench calibrated correctly? has it been stored in a very well manner? or banged around in a tool box and dropped often? mine are in a foam padded drawer in my box with other sensitive tools
Old Apr 27, 2010 | 05:15 PM
anthony g's Avatar
Thanks for the help guys. I had 2 head bolts that were damaged. Will change all the head bolts and see what happens from there.
Old Apr 27, 2010 | 05:45 PM
ThatGuy522's Avatar
i would also get the head checked for warpage
Old Apr 27, 2010 | 05:48 PM
builthatch's Avatar
MiG-21 superfan
absolutely check the deck and head for warpage at this point, despite your findings about the bolts. this can be accomplished with a legitimate straightedge and feeler gauge, but ideally it should be perfectly flat with the straightedge.
TECKSTEREX
Mar 9, 2018 05:29 PM
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
JamesB1985
Mar 5, 2013 06:58 AM
DaYZeD.1
Mar 28, 2008 09:19 AM
austincrx
Sep 7, 2006 09:49 AM
