Civic and Integra parts, B and D series parts, exhaust parts, tires – Providence, R
Old Apr 25, 2010 | 08:58 AM
94CivicSi's Avatar
Default Civic and Integra parts, B and D series parts, exhaust parts, tires – Providence, R
My landlord is having work done in the basement and on the garage, so I need to either get rid of these parts or move them. I’d prefer to get rid of them.
Demolition starts TUESDAY, so if you’re interested in a part, get at me ASAP with an offer. I’ll keep it upstairs in my apartment even if we can’t get together before then.
Everything is located in Providence, RI. MAKE OFFERS! Lowball where appropriate.
OBX Twin Loop stainless muffler. Used but in good condition. I was going to paint it black, primed a section on the bottom, then stopped.
Basic Magnaflow muffler. Put it on your beater.
stock B18B1 OBD2 exhaust manifold It has new gaskets in the junction. I don’t have bolts for the heat shield.
used aftermaket catalytic converter w/ OEM 2” flange It throws a code in an OBD2 car. MIGHT work in an OBD1 car, but can’t make any promises.
used aftermarket OBD1 catalytic converter w/ OEM 2.5” flange. You could add an o2 bung to convert it to OBD2.
used reman’ed B series axles. Boots are in good shape, but there is some inner CV wobble around 30mph.
OEM B series intermediate shaft bearing kit. Include the bearing, shim and both c-clips, all NEW in their original packaging.
FULL SET of Bridgestone Poternza G019 Grid’s – 195/60-15 These were on my wife’s Volvo when we got it. About 10K miles on them, 8/32” left all around, no camber wear.
Testing waters Disassembled, but complete, D16y8 I tore this motor down to rebuild it, but the loss my of me garage and basement are going to make that impossible. Honestly, you’re going to need to take the whole thing, otherwise, I will store it at my Dad’s house until I’m able to bring it home again and reassemble. If you’re interested, PM me for details on this motor. Simple rebuild, good for a beginner or SOHC turbo build.
I have every component of a 2000 EX drivetrain to accompany it if you’re looking for a full swap.
That’s what I’ve got for now. Going to head back down to the basement and see what other small parts I’ve missed. I’ll be online all day, so PM or post w/ questions or details.
More to come……
Old Apr 26, 2010 | 08:46 AM
94CivicSi's Avatar
Default Re: Civic and Integra parts, B and D series parts, exhaust parts, tires – Providence,
More stuff....
92-95 Civic 9.5” non-ABS front knuckle assembly – will separate
Make offers on parts you need/desire or as a package.
Knuckles: bearings are shot, lower ball joints were newly installed though
Rotors: Brembo blanks, low mileage
Pads: Axxis Ultimates, low mileage
Calipers: approx 180,000 miles, were working fine when they came off, missing (1) banjo bolt
OEM rebuild kit for 9.5” front calipers
Asking $15
One unopened, one opened to see if I could use any of the parts on 10.2” calipers, but could not. Complete:
NEW Axxis Ultimates for 9.5” front calipers
Asking $30
96-00 Civic rear drum assembly – will separate
Make offers on parts you need/desire or complete package. Everything came off a 2000 EX w/ 69,000 miles. Includes unopened drums, e-brake cables, rubber brake lines and prop valve.
94-01 Integra rear trailing arms + compensator arms
Make offer
Civic rear trailing arm brake line brackets – drum only
Make offer
B18b1 OBD2 engine wiring harness
Distributor and CFK plugs have been cut off. Take what’s left or make me an offer for specific plugs.
DOHC VTEC valve cover gasket set – incomplete
Asking $20
Gasket and plug tube gaskets are there, but I took the washers for my LS.
OEM 22mm sway bar bushings for CTR/ITR rear sway - used
Asking $5 + shipping
92-95 Civic rear tailgate catches
99-00 Civic hazard switch
D16y8 engine wire harness cover and intake manifold bracket
Make offers
B18b1 drivers side engine mount
Asking $15 + shipping
Integra P73 AC compressor bracket - no stud or adjuster
Asking $10 + shipping
DC2 AC compressor
Make offer
Some of this stuff will probably go in the dumpster that was just delivered to my house if no one wants it, so again, if you have ANY interest in anything, let me know.
Old Apr 26, 2010 | 09:01 AM
turbo_civicd16's Avatar
looking for a vtec solenoid (d series) and y8 intake mani what prices you got on those?
Old Apr 26, 2010 | 09:39 AM
94CivicSi's Avatar
Not sure I'm up for parting the y8 since I know I'll be stuck with most of it in the end. Let me think about for a few and I'll get back to you.
Old Apr 27, 2010 | 05:33 AM
94CivicSi's Avatar
up
Nextelopy
Sep 13, 2018 05:37 PM
limpingalong
Apr 24, 2015 12:07 PM
