CRX Custom-Fitted Car Covers
********** CUSTOM FITTED CAR COVERS ************
2 Like New (no tears, no stains, perfect fit) custom-fitted car covers for CRX's, each were $200+ and are barely used:
1. Coverking Custom Car Cover - Stormproof $110 shipped
The culmination of over 15 years of development, Stormproof™ material is designed by Coverking and made by one of the world's leading textile mills. It is the most waterproof yet breathable car cover material available. Stormproof™ car cover material exhibits outstanding sun and U.V. resistance, able to last for years in Arizona sun without fading. The micro-fiber base material is soft to the touch and won't scratch a car's paint - yet is rolls up into a very compact package for easy storage.
Through Coverking's advanced textile engineering, Stormproof™ accomplishes the needs of a premium Car Cover material without the coatings which can easily wear off, the treatments which fade over time, and the processing which can be undone the first time it is exposed to water. Speak to somebody who has owned other "premium" Car Cover materials and you'll hear how the other Car Cover fabrics work as advertised for the first few months, but then degrade in their water resistance - the problem is that the treatments and coatings can wear off, scratch off, or simply wash off.
2. Covercraft NOAH Custom Car Cover $100 shipped
NOAH barrier fabric actually stops water, yet it "breathes" to allow any trapped moisture, seam seepage or condensation to easily evaporate. The unique construction process (patent pending) results in a cover with maximum all-weather protection...highly water resistant, dust resistant, UV resistant and breathable to make sure moisture and/or heat don't stay under the cover. Made in the U.S. by Kimberly-Clark, the fabric weighs only 4.45 oz./sq. yd., so it's easy to handle and fold.
Protective Outer Layers - A bi-component spunbond, using sheath-core technology. The inner core is polypropylene for strength, with a polyethylene wrap for softness. A silver-gray color was selected because of its heat-resistant properties. The fabric is also treated with UV inhibitors for extended outdoor use.
Micro-Porous Middle Layer - The barrier layer is breathable film, a proprietary stretch-film technology developed exclusively for Kimberly-Clark. The film is stretched and subjected to a chemical process that creates microscopic holes smaller than droplets of water or dust, yet large enough to allow moisture vapor to escape.
Soft, Paint-Protecting Inner Layer - A bi-component fabric made with polyethylene and nylon. This combination results in an exceptionally high strength-to-weight ratio, with the "soft touch" necessary for today's water-based paint finishes.
*Boostwerks*
Aug 24, 2005 03:41 PM
