b-series swap questions...
I hate to ask, because I know there are thousands of swap threads already out there, but I have a few more specific questions.
This will be my first time swapping an engine almost completely by myself. I have a 93 Civic VX hatch. The engine going in is a B18B bottom end with a B16A1 head. I just want to be sure the parts I have are the correct parts needed for my specific engine and vehicle.
P28 ecu - will it work being a virgin ecu?
non ABS 94+ Integra axles - didn't know what the difference between having ABS and not having it would be?
wiring for Vtec - I have 3 wires coming off my Vtec solenoid but not so sure what they all need to go to....?
Integra engine wire harness - not too sure what year this harness came off of, but do I even need it?
I appreciate anyone who can help me with more than "did you search?".
Thanks in advance.
Thanks in advance.
Your stock mounts @ wiring harness retroed,94-01 teg shift linkage, Its really easy as puttin the sohc back in your bay and your vx eng harness should be equiped with vtec plugs. knock sensor and dohc vtec ecu or ur chpd p28 will tie your shoe laces once in 4 all.
