B16A questions
I need some help, here is the spec of my EK,
Engine: stock B16A with the following modifications,
- ITR IM
- ITR throttle body
- ITR intake and exhaust cam
- Skunk2 cam gear set at 0,0
- 2 layers Spoon head gasket
- EK9 ECU (PCT)
- Spoon 4-2 + ITR 2-1 header
- Stock EK9 catback exhaust
Engine compression 210 across all 4 cylinders. The car is mainly driving on the street.
Problem,
1) The engine has been consuming about a liter of oil every 1000 miles that is after replaced the PVC valve. It was even worst before replacing a new PVC, so now i found my IM is very oily inside (black color) and i expect there is alot of build-up inside the combustion chamber. And i have heard that the build-up could affect the oil consumption. Is there a way to fix it. Seafoam?
2) Is the thermoblock for intake manifold and throttle body worth getting??
http://www.outlawengineering.com/HondaB16AFrame.html
Thanks for the comment and help.
- ITR IM
- ITR throttle body
- EK9 ECU (PCT)
Problem,
To be honest i don't see any smoke when idling and i don't see any smoke in the rear view mirror when driving, maybe i am too busy watch the road. I don't have black rear bumper. I need to ask my friend to follow me to found it out.
Sounds like your oil control rings are stuck. Oil in the intake manifold is from blow-by suggesting your rings are worn. Try doing a leak down test and see what you get.
What option do i have?
1) pull the engine out and replace with oversize CTR piston & rings
2) put some engine cleaner in such as seafoam and hope that the oil control rings to un-stuck from the build-up
Any suggestion? Thanks.
Spoonson
Apr 6, 2007 06:40 AM
