94 Integra b20 rough idle
Old Apr 24, 2010 | 11:14 PM
SkidmarkEH2's Avatar
Default 94 Integra b20 rough idle
So I recently swaped a b20b in my 94 integra ls and now I seem to have a rough idle. It almost sounds like a missfire. I've already changed the IAC valve, new plugs and wires. I've cleaned out the fast idle thermo valve. I've even adjusted the idle screw out. I searched and found nothing. Any body have any ideas!?
Old Apr 25, 2010 | 01:23 AM
dunkXdrift831's Avatar
Default Re: 94 Integra b20 rough idle
have you checked the timing? maybe a vacuum leak?
Old Apr 25, 2010 | 07:59 AM
timing is dead on. i had it timed to 16. its not a vac leak, i'm pulling 20 vac. and it seems to run a little better with a vac leak lol. i forgot to mention im running a chipped p75. i have the same prob running the ls map as i do with the b20 tune. ive even tried swapping out ecu's and that didnt help.
Old Apr 25, 2010 | 08:00 PM
Bump
Old Apr 25, 2010 | 09:47 PM
LordAphotic's Avatar
do a compression test. sometimes if u were running lean u mighta burned through a valve and it will cause it to idle so low it wants to turn off
bigodub93
72
Mar 28, 2014 06:36 PM
blacknightteg
Jun 16, 2009 09:57 PM
expressivepinoyboy
Feb 19, 2009 05:37 PM
revhardallday
Dec 13, 2008 09:21 AM
mugen92acintls
Dec 28, 2004 05:38 PM
