Milled head, decked head
.20 is roughly 1 point in an 81.5mm bore .046 is alot, i would be very concerned about p to v clearance. i wouldnt advise taken that much material off. your gonna run into ptov clearance issue as well as timing issues and its gonna be hard to find a cam gear with enough adjustability to compensate for the extreme change in deck height
piston to deck height
-0.033 (Meaning that your piston would stick that far out of the block)
If you add the thickness of the head gasket
0.026
you are left with
0.013 clearance
Compression ratio
10.7:1
0.026
you are left with
0.013 clearance
Compression ratio
10.7:1
He can't take that much off unless he plans on running a thick head gasket. Ideally you want to have around .030 between your piston and your head to help dissipate heat and lower the risk of detonation.
http://www.zealautowerks.com/bseries.html enter everything from your setup, and in the head milling and block decking section put your .046
InfamousRS
May 2, 2002 12:58 PM
