which clutch should i use for my gsr?
HI there everyone i was wondering which clutch should i use for my gsr. my mods are intake, header, muffler, stage 1 cams. let me know which clutch is the best to use for these mods and wat brand, and stage should i use. thanks.
OEM Acura Integra TypeR clutch is the best. Unless you are tracking your car, you don't need a stage whatever.
If you are on a budget, just go on ebay and search integra exedy clutch. Get the factory clutch kit.
Here is a link. I was feeling nice.
http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
the exedy is not oem, fuji carbon is oem. the exedy oem replacement clutch is very similar to the fuji but has a shittier throw out bearing. you can get the exedy/fidanza combo from gripforce for under 300 if you would like to shave some weight off the nose of your car and make the car a little faster to rev match. the exedy stage 1 is also a reinforced organic disc that holds up to track use quite a bit better with lower hp applications, like under 240hp. finally, the gsr and type r have the same clutch, the R just uses a slightly lighter flywheel stock.
