Need an idea what do build.
Old Sep 10, 2002 | 09:29 PM
Attoir's Avatar
Default Need an idea what do build.
Got a '89 HF, perfect body. Stripped, nothing but a steering column and fusebox in it. No wiring harness, no tar, no heatshielding on the firewall. *Stripped*.
What do I build it into? I'm about to pop in an HF swap so I can drive it back and forth to work (30 minutes away, lonely highway.) Need a reliable car, 'cause my Jeep is becoming a bit unreliable. but it'll be fine for school and local stuff.
Should I save up cash for a full, quality paint job? I want Championship or Frost white. Or should I just get a new coat on the exterior, keep it some shade of red (original / interior color)?
What engine setup should I go? I wanna stay D-Series, and I've got a Z6 swap I can build / use.
I don't know. Tell me what you guys would do if you had a Civic Hatchback chassis, a Z6, and lots of time to build on it.
Old Sep 10, 2002 | 09:32 PM
spettinger's Avatar
Default Re: Need an idea what do build. (Attoir)
i would never want another d series after living the dream that is B series (haha) but i would say to get some higher compression pistons and mill the head, then get some sort of big cam. you are probably looking at about $1000 so far, at least you already have the motor.
Old Sep 10, 2002 | 09:48 PM
Attoir's Avatar
Default Re: Need an idea what do build. (wreckedhatch)
eh, D16Z6 would be my last choice for doing all motor.
Old Sep 11, 2002 | 06:34 AM
markedOO1's Avatar
where did he say he wanted to stay all motor... (or did I miss it? )...
Old Sep 11, 2002 | 08:24 AM
ijjz's Avatar
Don't underestimate the power of sohc's!
Old Sep 11, 2002 | 08:41 AM
Mr Furball's Avatar
Default Re: Need an idea what do build. (ijjz)
B16 =
Old Sep 11, 2002 | 09:41 AM
zcivic91's Avatar
Default Re: Need an idea what do build. (FURBALL B-16)
na..heres wat to do...
tare down the motor and start by getting forged pistonsand eagle rods. the some acl bearing and arp heads studs
buy a zc lsd tranny and axles to go with it..
have the head ported and polished..not milled..
get a turbo cam and cam gear
get 450 cc injectors froma talon
get a vafc
get a greddy turbo
put together...and dyno tune
kick ***..
obviosly you can leave stuff out thats out of your budget..but main idea...turob sohc vtec in hf..13's easy..kick *** on the street and road course..
Old Sep 11, 2002 | 09:43 AM
Mr.JaCkeL26's Avatar
Default Re: Need an idea what do build. (zcivic91)
build the motor then turbo it....
Old Sep 11, 2002 | 01:21 PM
Brandon Chun's Avatar
build up the Z6, Greddy Turbo Kit w/ Intercooler, this is what I want to do next.
Old Sep 11, 2002 | 01:30 PM
MrTodd's Avatar
Default Re: Need an idea what do build. (Brandon Chun)
If you're gonna go turbo, do it right with a B18! Don't waste your time building up a D series IMO, 'cuz you can get better performance with a bigger B series.
Now, if you want to stay D series, then definetly use the Z6 block, but then slap a Y8 head on there! If you could also get a hold of some A6 pistons, use those instead of the Z6 pistons (higher compression).
That should be pretty quick (almost done with mine) especially with a HF!
So far my swap is pretty much just like dropping in another d16a6, except for the Vtec activation. I'm gonna use a Zdyne conversion ecu, but whatever you use, make sure you have the extra fuel to compensate for the vtec. (zdyne ecu comes with the Y8 fuel/timing maps)
Good luck!
Old Sep 11, 2002 | 01:46 PM
slowman's Avatar
I took way too long
put in the z6. get a junkyard turbo if youre short on money. enjoy the results.
MastaFlyMason
14
Aug 6, 2017 03:43 AM
SupraRXZ
Apr 5, 2006 03:55 PM
rice a roni
13
Oct 25, 2004 07:52 PM
RAS Motorsports
10
Aug 5, 2004 07:47 AM
lilcasino
Oct 18, 2002 05:47 PM
