Can EP3 shocks/springs fit 03 RSX Base?
Old Apr 24, 2010 | 02:28 PM
Agent_Samz's Avatar
Default Can EP3 shocks/springs fit 03 RSX Base?
I have a 2003 Acura RSX Base and someone is offering me a great deal on some koni shocks and H&R springs off his 03 Civic SI. Will these fit onto my RSX with no problems? Please let me know and provide any help if possible. I'm about to buy these but want to make sure, thanks.
Old Apr 24, 2010 | 02:55 PM
EPTech's Avatar
Default Re: Can EP3 shocks/springs fit 03 RSX Base?
yes they will fit. the 05-06 rsx springs are wound in different directions so you luck out
Old Apr 24, 2010 | 07:46 PM
Agent_Samz's Avatar
Ok so the shocks fit fine as well? Im worried about the shocks. They are koni yellows
Old Apr 25, 2010 | 07:44 AM
Agent_Samz's Avatar
bump
Old Apr 26, 2010 | 06:21 AM
Agent_Samz's Avatar
ttt
Old Apr 27, 2010 | 06:04 AM
Agent_Samz's Avatar
bump
Old Apr 27, 2010 | 08:06 AM
WhiteOnRice's Avatar
I believe they will work. I remembering hearing you need to modify struts to go from rsx to ep but not the other way around.
Is the seller local? I'd make sure they fit before buying.
Old Apr 27, 2010 | 10:26 AM
dohcem1's Avatar
I think if you have an rsx and your putting on the ep struts, the front you have to get ep tie rod, and the rear you might need washers where the strut connects to the control arm. Cause the bushing of the rear for the ep is smaller/narrower than the rsx. Hence people with ep3 has to grind down that part if they use the the rsx struts.
djviet2000
Feb 1, 2011 06:28 AM
partsman24
Honda Civic (2001 - 2005)
Jul 31, 2008 03:08 PM
02whiteDC5
Aug 11, 2007 06:27 AM
