jdm itr cat question
Old Apr 23, 2010 | 02:52 PM
replicaITR417's Avatar
Default jdm itr cat question
Im running jdm itr 96 spec in a 96 gsr obd2, and i'm using the jdm 96 spec itr ecu that came with it which is also obd2.
I just purchased the entire jdm itr exhaust system header, cat, b pipe, exhaust. there's is 1 o2 sensor on the header, but there is no o2 sensor on the cat. will i get cel codes thrown at me since I dont have a second o2 on the cat?
since i'm running the ecu and that cat, which they both mate together in japan, im assuming i wont get any problems, but does anyone know for sure?
Old Apr 23, 2010 | 05:01 PM
mugenracer's Avatar
Default Re: jdm itr cat question
The sensor in the cat is a temp sensor and not an O2 sensor. You dont need it and you wont get any CELs without it as it isn't hooked up to the ECU.
Old Apr 23, 2010 | 08:17 PM
wego5typer#431's Avatar
You should be fine running a jdm ecu, you will only run into problems if you hook up a usdm ecu
Old Apr 23, 2010 | 10:03 PM
awesome thanks. i have 2 of these cats, it got me thinking for a little bit because one has no o2 and the other one has a really small bung with a sensor that i thought was the o2, but i guess it is the temp sensor that you're talking about.
Old Apr 24, 2010 | 01:49 PM
mugenracer's Avatar
They done away with the temp sensor in the cat on the 98spec JDM ITR so it was only found in 96specs, so you have a 98spec and 96spec cat. Run the 98spec cat as it'll be newer and wont have the sensor that you dont need anyway.
Old Apr 25, 2010 | 05:20 AM
MetalicMan's Avatar
x2
Rikaro
Sep 6, 2009 03:22 AM
integra123
Sep 20, 2006 02:26 PM
KriLYu
Northern California (Sales)
Feb 9, 2006 07:37 AM
REDTOPAlchemy
Aug 23, 2004 12:48 AM
nadc2
Mar 19, 2003 04:16 AM
