Work RB Gear Variance Field
Old Apr 23, 2010 | 01:35 PM
ktcb7's Avatar
From: ::Reppin' cb7 all day, in the city of trees::
Default Work RB Gear Variance Field
Okay, I have a set of the Work RB Gear and on of the lug nut plates is damaged and I want to get it replaced.
Does anyone know where I can either find the lug nut plate by itself or even the whole center cap setup?
Heres some pics of what I'm talking about. Thanks.
HELP PLEASE!
Damaged plate on wheel.
Good plate on the left, Bad plate on the right.
Damged plate.
How the plate is supposed to look.
Old Apr 23, 2010 | 02:53 PM
r.wright's Avatar
Default Re: Work RB Gear Variance Field
nice wheels. i had some of those about 10 or more years ago.
im pretty sure all those 16" random ewing wheels share the same bolt patten on their barrels. hint hint.
for example: http://poseidon-group.com/psdphoto/726-4.JPG
yahoo japan auctions is a good place to go to and rinkya is a pretty good source to get the wheels here.
Old Apr 24, 2010 | 12:22 AM
ktcb7's Avatar
Ok thanks I've been searching around and have seen some that would possibly fit but nobody wants to sell them separate.
Old Apr 24, 2010 | 07:26 AM
r.wright's Avatar
Gotta do what I did/do.... Buy the whole wheel then swap over the leftovers when you're done then resell.
I know its a long, expensive and tedious process but I can honestly say it has helped me ten fold in my learning process
There were times when I'd wait for a shipment then it would be the wrong wheels so back to the drawing board and had to reorder other wheels til I got it right.
Also, I'm sure those caps/plates interchange w/other models of mid 90's work ewings.
I think rb gear was some aftermarket parts/tuning company from back in the day and they wanted a rim built to rep their name. Gotta do what I did/do.... Buy the whole wheel then swap over the leftovers when you're done then resell.
Also, I'm sure those caps/change interchange w/other models of mid 90's ewings.
Old Apr 29, 2010 | 02:23 PM
ktcb7's Avatar
Still no luck!
Opposum pm me on how to order from yahoo japan or rinkya.
Old Apr 29, 2010 | 05:18 PM
r.wright's Avatar
all the info is here:
http://www.rinkya.com/
ic3pham
Sep 26, 2011 10:59 AM
ktcb7
Northern California
11
Apr 30, 2010 07:41 AM
DeLiRiOu5
Jan 14, 2004 06:11 PM
sivik2nr
Oct 1, 2002 03:07 PM
Flux
Apr 23, 2002 05:55 PM
