what is a clutch cable used for?
Old Apr 23, 2010 | 09:59 AM
crazy bum's Avatar
Default what is a clutch cable used for?
did some research.couldnt find anything.. and i noticed iam missing mine...what does the cable do exactly? and would it matter if i picked one up at the junk yard or do i gota get a brand new one if i need it?
Old Apr 23, 2010 | 10:12 AM
miguey310's Avatar
Default Re: what is a clutch cable used for?
it's for a cable tranny , it's use to put the car in gear and for the clutch to engaged
it's better to get a new one cause if you get a old one and not gonna work right
and get the oem one than the aftermarket
Old Apr 23, 2010 | 10:40 AM
JCRXTURBO20916's Avatar
NEW OR USED AS LONG AS ITS IN GOOD SHAP.
WHAT A CABLE DOSE WHEN APPLY IS PUT PRESSURE TO A FORK IN THE TRANSMISSION
INTURN APPLYS PRESSURE TO THE THROW OUT BEARING, AND THE BEARING APPLYS
PRESSURE TO THE CLUTCH PRESSURE PLATE WITCH ALLOW THE TRANSMISSON TO SHIFT INTO THE DESIRED GEAR THAT YOU CHOSE.
Old Apr 23, 2010 | 11:35 AM
EL Vap133's Avatar
I would get a new one too, I believe they are about $40 new from Honda.
If you get a used one you run the risk of getting one that is no good or has been stretched out, etc.
Old Apr 26, 2010 | 11:30 PM
crazy bum's Avatar
does the car still run if its not there?
Old Apr 26, 2010 | 11:55 PM
mayfly's Avatar
it will turn on but u cant put it into gear. u cant drive without it
Old Apr 27, 2010 | 06:50 AM
89LSED's Avatar
I beg to differ. It is not easy, but you can drive the car with no clutch at all.
Ive had to do it when my clutch cable snaped.
you start the car in gear, it will lurch you forward. then you just slid threw the gears. then pop it into neutrel, coast to a stop. shut it of, put it into first, and start all over again.
haha
Its not the funnest process in the world, but it is doable.
Ive even got into the habit of not clutching during regular driving, other than starting and stopping. And as long as you dont miss a gear, its not hard on the tranny at all.
I know this isnt what the OP was asking about, but i just wanted to throw it out there thath NOTHING is impossible!! Haha
Old Apr 27, 2010 | 07:35 AM
EL Vap133's Avatar
I have driven without a functioning clutch cable before, I would start out in 2nd gear and shift after rev matching.
Old Apr 27, 2010 | 08:09 AM
crazy bum's Avatar
lol dam that sounds like a bit of a hard time, has anyone ever heard of while when your racing someone shifts threw gears like 1st to 2nd 2nd to 3rd ect.. without clutching?my friend use to do that when he use to have his eg coupe, well atleast i was told he did that...****s up the tranny real bad doesnt it?
Old Apr 27, 2010 | 08:15 AM
89LSED's Avatar
I know they have dog box trannys for the DSMS but i dont know about for hondas.
I would think that would kill a tranny. Because you cant revmatch an 7-8k. It just doesnt work... i dont think
Old Apr 27, 2010 | 05:30 PM
michael O's Avatar
I think its called powershifting and it's done by a lot of drag racers. But yea most of them have dog geared transmissions.
Old Apr 27, 2010 | 06:49 PM
crazy bum's Avatar
what is a dog geared/box trans and what does it do?
Remiss
Jun 2, 2009 05:09 PM
stockcrix1616
Nov 30, 2006 08:47 AM
88crxdxfastwhip
Sep 4, 2005 09:18 PM
