Whats wrong with Camber Kits?
Old Sep 10, 2002 | 07:41 PM
95 GaNgStA AcCoRd's Avatar
Default Whats wrong with Camber Kits?
There was a post a few weeks ago, I can't remember what it was titled, and right now i'm too lazy to search but it had something to do with suspension. N E ways, I noticed alot of you were taking off your Camber Kits after a year or so, and I wanted to know why? What is it that happends to them?
Old Sep 10, 2002 | 07:48 PM
Accord94DX's Avatar
Default Re: Whats wrong with Camber Kits? (95 GaNgStA AcCoRd)
clearance issues between the a-arm and the body is why i pulled mine out.
Old Sep 10, 2002 | 07:52 PM
Default Re: Whats wrong with Camber Kits? (Accord94dx)
What did it do? I'm new to the whole suspension thing.
Old Sep 11, 2002 | 09:54 AM
Accord94DX's Avatar
the upper A-Arm (control arm) hit the body when going over any sized bump. This was because the camber kit pushed the A-Arm out in order to correct the camber.
A poorly designed kit.
Old Sep 11, 2002 | 10:09 AM
kcxtremeaccord's Avatar
brian whats your spring strut setup?
[Modified by ILiveNextToSabastian, 11:09 AM 9/11/2002]
Old Sep 11, 2002 | 10:14 AM
Accord94DX's Avatar
Default Re: Whats wrong with Camber Kits? (ILiveNextToSabastian)
H&R race with Koni Adjustables.
Old Sep 11, 2002 | 10:16 AM
ArchAngel Sabastian's Avatar
New User
what did you do for camber? im wondering if ill need a kit with just sport springs.
Old Sep 11, 2002 | 10:19 AM
Accord94DX's Avatar
Default Re: Whats wrong with Camber Kits? (Sabastian)
Washered out the rear, went through two camber kits on the front without success till i just said, "to hell with this!" and left it negative.
Old Sep 11, 2002 | 10:26 AM
Brandon's Avatar
Life is Suffering
I have an Ingalls kit, and it has worked fine for the 1 1/2 years I have had it.
Old Sep 11, 2002 | 11:06 AM
jjj784's Avatar
Default Re: Whats wrong with Camber Kits? (F22turbo)
have you guys tried grinding down the A-arm or spreading the legs of the control arm for clearance? what about the "new" ball joint camber kits? i hear that doesn't pull the A arm as much compared to the other camber kits that correct at the legs of the A arm.
Old Sep 11, 2002 | 01:20 PM
KCHybrid's Avatar
Default Re: Whats wrong with Camber Kits? (jjj784)
Just rotate every 3k negative camber is good
Old Sep 11, 2002 | 02:03 PM
exvtec94's Avatar
brandon,
which ingalls kit do you have? -3/4 to 1 or 1.25 to 3?
Old Sep 11, 2002 | 10:18 PM
Default Re: Whats wrong with Camber Kits? (exvtec94)
Brian with 17's and a 2 inch drop do u think its better with or without the kit?
Old Sep 11, 2002 | 10:19 PM
Accord94DX's Avatar
Ingalls kit you SHOULD be able to get away with fine. I bet you will. If it does have issues they will be so slight that a lil "convincing" with a +16 ounce hammer will solve them.
Old Sep 11, 2002 | 10:54 PM
Default Re: Whats wrong with Camber Kits? (Hennessey and Extacy)
lol @ lil convincing. how much is the Ingalls?
Old Sep 11, 2002 | 10:58 PM
ekk's Avatar
ekk
u should be able to find the ingalls for 130shipped on groupbuy .. i just put mines in today, getting alignment tomorrow so we'll see how it goes
Old Sep 11, 2002 | 11:03 PM
Default Re: Whats wrong with Camber Kits? (ekk)
coo thanks. I gotta get an alignment too
Old Sep 12, 2002 | 04:29 AM
Stew Pidasso's Avatar
My one side (front) camber kit has caused big problems.The one upper control arm has smashed through the body (lip) in the fenderwell.The driver's side has been stuck above that lip for a while now.Well the other day I pulled out of my driveway and started to go forward.The car clunked and just hit the ground.I got out and apparently the lower ball joint has pulled out of the lower control arm. I believe this to be because when the suspension wasn't allowed to travel back down (over a bump or dip) it was supporting all of the weight of the tire/lower suspension and caused either the cotter pin to shear and back off the crown nut or the crown nut just stripped.Either way now my fender is completely f&*%ed up from the tire bending back and hitting it.The half-shaft pulled out of the tranny and is bent.The ball joint is also screwed.I will post pics as soon as I feel like uploading.
It was weird at first because I would jack up the car and the driver side front tire would stay up in the wheel well. to me for not fixing it then....
Old Sep 12, 2002 | 05:49 AM
Accord94DX's Avatar
Default Re: Whats wrong with Camber Kits? (Nitz5785)
Nitz, with your fleet of accord parts runners, you should have the good one on the road in no time. Pictures always help
Old Sep 12, 2002 | 05:59 AM
dcaccord's Avatar
I have the adjustable ball joint kit on the front. It's by K-Mac. It works great without any fender clearance issues. I got it from Manchester Honda a few years ago. It wasn't cheap though.
Old Sep 12, 2002 | 06:38 AM
LOL
Yeah but my part runners don't include money for the new parts
Old Sep 12, 2002 | 08:17 AM
Accord94DX's Avatar
LOL
Potentially, they do.
Could you bear to part with one?
Old Sep 12, 2002 | 10:48 AM
LOL
I'm sorry but I love them both dearly...
EDIT: I drive one of them to and from work everyday and when my '94 is in pieces (which is usually the case).Ones auto with power features but the other is a 5spd with AC so.....
[Modified by Nitz5785, 2:50 PM 9/12/2002]
Old Sep 12, 2002 | 11:15 AM
Accord94DX's Avatar
I understand. I have an 89 LXi coupe. It will never die.
Old Sep 12, 2002 | 09:27 PM
Nitz how did the control arm smash through the body in the fenderwell?
