DX/Si/Hf Rear trailing arms the same?
To start off with: I have a 1990 CRX Si
One of my trailing arms is bent, and I'm having a hell of a time finding one with rear disk in local junkyards.
I'm finding nothing but cars with rear Drum. What I'd like to know is if the trailing arms are exactly the same, so I can do a hub swap then transfer everything from one arm to another.
Thanks
Thanks
Yes, the 90-91 CRX Si is the one with the rear disc brakes. The trailing arms are interchangeable though you need to remove all those drum brake pieces to mount any rear disc brake pieces.
I know that the hubs are different, and that 90-91 Si's were the only ones that came with rear disk. Just trying to find an alternate way to move everything (Hub, brakes, brake line holder, etc..) from my bent arm to another DX trailing arm, after removing all it's parts.
jacksonww
Oct 5, 2010 05:09 AM
