For those of you with aftermarket steering wheels!
Old Sep 10, 2002 | 07:08 PM
CarbonfiberR's Avatar
Default For those of you with aftermarket steering wheels!
I just replaced my factory airbag steering wheel in my 00 civic hatch for a momo one and cant seem to figure out how hook up the horn. Is there something I am missing?
Old Sep 10, 2002 | 07:12 PM
DualKnuttz's Avatar
Banned
Default Re: For those of you with aftermarket steering wheels! (CarbonfiberR)
I swapped a momo one on my 94 and I cant hookup the horn also. The stock horn is hooked up by this mechanism that allows power to run to the steering wheel while the wheel is turning and I had to remove it to make the hub fit. I just ran a separate button to the horn. kind of a drag but its the sacrifice for a nice steering wheel.
Old Sep 10, 2002 | 09:21 PM
eg6sir-s's Avatar
kgrcr1 has done it to a few cars, including mine. i'm sure he can help you guys out if you ask.
Old Sep 10, 2002 | 11:38 PM
dnt94civic's Avatar
Default Re: For those of you with aftermarket steering wheels! (eg6si)
Here you guys go
Go to the section about installing the horn
https://honda-tech.com/zerothread?id=273474
[Modified by dnt94civic, 12:39 AM 9/11/2002]
Old Jun 18, 2003 | 08:44 AM
ohyeah88's Avatar
Default Re: For those of you with aftermarket steering wheels! (DualKnuttz)
did you have to unplug the passenger side airbag to keep it from popping out? I was going to install a momo steering wheel, but I wasnt sure if the passenger side airbag would remain functional
Old Jun 18, 2003 | 10:04 AM
civicracer99's Avatar
This is for anyone. I got a 98 civic EX and if I replace the stock steering wheel for an aftermarket one, than where, if possible do I relocate the cruise control switches to?
Old Jun 18, 2003 | 10:16 AM
Marauder's Avatar
Default Re: For those of you with aftermarket steering wheels! (civicracer99)
I have a Sparco wheel.....now I don't have a horn or cruise control. I never use cruise control anyways, and with a turbo it doesn't work well when your into boost...since it loses vacuum. Horn....well, I just chirp my BOV at people!
igorka_91
Sep 10, 2010 11:00 PM
eJ6DM
Jan 4, 2006 01:44 AM
W O T
Sep 22, 2005 09:05 PM
silver ej
Jul 9, 2005 09:48 AM
