need pointers on a n/a build for track only
Old Apr 21, 2010 | 08:54 PM
jdmnic91's Avatar
Default need pointers on a n/a build for track only
ok. a couple of friends and I are going to do a all motor honda build for the strip. need some pointers on what parts are good for great power for n/a since im used to building dd's. the goal for now is 300hp. we already have the car and suspension ready to go.
what block and head are best to use?
camshafts?
valvetrain?
pistons?
rods?
crank?
intake?
exhaust?
fuel components?
will hondata be a good start for tuning?
and anything else that would be best?
Old Apr 22, 2010 | 02:52 AM
Derek128's Avatar
Default Re: need pointers on a n/a build for track only
i guess k24block w/ k20 head is one of the easiest way
Old Apr 22, 2010 | 03:12 AM
hondamark35's Avatar
what's your budget?
what chassis do you have?
what have you built in the past?
what have your friends built before?
where did the 300-350hp goal come from?
Old Apr 22, 2010 | 03:14 AM
negusjuda's Avatar
i second that k is the way to 300 n/a whp cause ya wont get it in a b series
Old Apr 22, 2010 | 07:50 PM
jdmnic91's Avatar
remember this will be a track only crx.
thinkin 13 or 14:1 cr
i've built 5 b series n/a dd motors (ls, b16, 2 gsr's, and a poor mans type R)
money is no issue for us right now.
Old Apr 23, 2010 | 02:25 AM
negusjuda's Avatar
k swap
Old Apr 23, 2010 | 04:58 AM
PirateMcFred makes a good point. although i will say it can be more rewarding to build a fast car than to buy one. Also, and it's nice to work on something you know well (i know, Hondas, Acuras and Toyotas- i probably wouldn't build a mustang because of the learning curve).
all that to say... it would be cool to see an all out V6 J-series set up for the strip... but the K20/24 would probably be the best fit for what you're asking.
Old Apr 23, 2010 | 03:44 PM
redGSRguy's Avatar
The OP did mention it was for the strip. My buddy has the k24/k20 setup runs 10.7 with about 290 hp. Skunk2 cams, DTR header, not too sure about the rest of it.
Originally Posted by PirateMcFred
If money's no object then try this:
http://cgi.ebay.com/ebaymotors/ws/eB...m=270566872694
Why limit yourself to a FWD CRX 4-banger if you can buy a high performance car that's got no question of performance capabilities?
Lemme guess, you mean "track" in terms of an extended 2-lane patch of asphalt 33.5 meters long and straight as a road in Kansas? That's a shame. If that's they way you want to go then you need to get a big turbo and a RWD Ford Foxbody. I can have respect for someone keeping 1200+whp and a short wheelbase under control over 7 or 8 seconds, not so much 200whp.
To each their own though I suppose.
Old Apr 23, 2010 | 08:42 PM
bauergold's Avatar
Guess you didn't read his post. He said he wants to build an all motor honda for the strip. That doesn't mean an ariel atom or a turbo foxbody.
I would go with a K24/K20 setup. Makes power very well.
Old Apr 24, 2010 | 06:48 PM
boostedef8!'s Avatar
K with bolt-ons and tuning can make that power but its gonna empty out your pockets.
Old Apr 26, 2010 | 10:11 AM
jdmnic91's Avatar
well right now a have:
skunk2 pro 3 cams and valve springs,
b16 head with port and polish and 5 angle valve job,
sleeved gsr block.
Old Apr 26, 2010 | 08:39 PM
Smokalicious's Avatar
do the research bro and u'll fined that u'll get the most power outta a K series you'll be maxed out at 300hp with a B series when 300hp on a K is mid way just my two cents btw the flatline boys have a k20 swap for sale haha
hoffdaddy
Engine Machining & Assembly
May 6, 2016 09:07 AM
hon2984
Feb 28, 2015 05:46 PM
jawnewbe2
Dec 26, 2013 02:19 PM
cigrafix2
27
Apr 21, 2007 05:00 AM
b19coupe
150
Sep 15, 2004 08:25 AM
