Is this true about JDM B16A alternators? (RESOLVED)
Old Apr 21, 2010 | 05:46 PM
BryanM.'s Avatar
Resident Gearhead
Default Is this true about JDM B16A alternators? (RESOLVED)
Long story short, I need a new alternator for my OBD1 B16A. I was literally just about to buy one for a B16A3 (Del Sol VTEC) when I decided to run a search and I came accross this thread:
https://honda-tech.com/forums/showth...ght=alternator
Is it really true that I need one for a 90-93 Integra because of the "weird brackets"?
UPDATE
Got an alternator for a '93 Integra, fit and works perfect. Unsure if a '94-'95 Integra alternator will work though.
Pulley and mounting points are the same.
Plug is the same.
One for the archieve.
Old Apr 21, 2010 | 05:52 PM
EM1 Resto's Avatar
Default Re: Is this true about JDM B16A alternators?
I know the OBD1 and OBD2 have different plugs.
Old Apr 21, 2010 | 05:59 PM
forcefedferio's Avatar
i know that they are different from JDM to USDM as in you must have a USDM bracket to run a USDM alternator, and vice versa. I would just get the del sol alternator and source a bracket just to eliminate a headache.
Old Apr 21, 2010 | 06:00 PM
BryanM.'s Avatar
Resident Gearhead
They sure do, but that's not a concern.
The brackets are though. I don't want to buy new brackets and a new alternator if I don't have to.
Old Apr 21, 2010 | 06:11 PM
BryanM.'s Avatar
Resident Gearhead
Thanks for posting man. I will do this if nesessary but if all I need is a DA alternator, that's even less of a headache.
I guess I just need someone to confirm that, but I will say philosofy1 (he posted in that thread) knows his stuff.
Old Apr 21, 2010 | 06:57 PM
98civdx's Avatar
Master Detailer
My friend had this issue about a year ago, and he tried a da and it bolted right on, and he has yet to have any issues.
Old Apr 21, 2010 | 07:02 PM
BryanM.'s Avatar
Resident Gearhead
Nice, I'm going to try it. Thanks for posting bro.
Old Apr 21, 2010 | 07:06 PM
98civdx's Avatar
Master Detailer
No problem.
Old Apr 24, 2010 | 06:40 PM
murdered sol's Avatar
good info, I gotta get a new alternator for my B16a also
oh BTW, from what I heard you can use a 94-95 teg alternator also. they're 90 amp instead of 65
Old Apr 24, 2010 | 08:57 PM
miguel329's Avatar
yup da one worked for my friends b16!
Old Apr 25, 2010 | 03:43 PM
BryanM.'s Avatar
Resident Gearhead
Updated.
Old Apr 25, 2010 | 04:28 PM
Red_Army's Avatar
so howd it work out?
i'll need to know incase mine ever craps out on me. to save me the headache now.
Old Apr 25, 2010 | 05:14 PM
BryanM.'s Avatar
Resident Gearhead
I updated my OP.
Fit and works perfect.
Old Apr 25, 2010 | 05:19 PM
98civdx's Avatar
Master Detailer
Glad it worked out, how much did the alt run you?
Old Apr 25, 2010 | 05:30 PM
BryanM.'s Avatar
Resident Gearhead
Thanks, it was $180.
Old Dec 6, 2020 | 09:27 PM
jhuerto23's Avatar
Default Re: Is this true about JDM B16A alternators? (RESOLVED)
Sorry to bring up an old thread. But will a non vtec 90-93 integra alternator work or does it have to be a GS-R model?
Old Dec 6, 2020 | 09:45 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Physically it will work, but the AMP output may be less than what your application needs, so verify the output of the product that you buy.
Old Dec 7, 2020 | 01:43 PM
tony_2018's Avatar
Fish Twig
Confirmed. I have a b16a2 on a d15b w/ modified upper bracket.
Old Jul 17, 2022 | 06:42 PM
Spaz253's Avatar
sorry whats da mean? My son has a b16a and he needs an alternator we're trying to figure out which one to buy / ask AutoZone for?
Old Jul 17, 2022 | 07:49 PM
JRCivic1's Avatar
10 Year Member
Community Builder
"DA" is a common reference for a '90-93 Integra chassis. What does the plug look like on the back of your alternator ? It could be the early large round dark green plug on your engine harness or the newer/later square light green plug on your engine harness. The former plug style application would use the '90-95 Acura Integra alternator, and the latter plug style would use a '96-01 Acura Integra (non Type R) alternator. If you want the highest AMP output, choose the Acura Integra GS-R fitment.
Old Jul 18, 2022 | 01:01 AM
Spaz253's Avatar
thanks you so much for ur help, not sure what r plug looks like yet, taking it out tomorrow.
Old Jul 18, 2022 | 08:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The Type R alternator uses the same plug style as the newer style '96-01 Integra's... but the housing and pulley are different and you don't need that mess... so stick with the list that posted for you and don't worry about what I steered you away from.
Old Jul 18, 2022 | 08:41 PM
Spaz253's Avatar
ok thanks, they always ask 7 or 8 L which do I tell them or does it matter. Didn't have a chance to do it today hopefully we can get it done tomorrow
Old Jul 19, 2022 | 07:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Do you mean 1.7L or 1.8L ??? This would be the difference between the '92-93 1.7L VTEC engine and the '90-95 GS/LS/RS 1.8L non-VTEC and '94-95 GSR 1.8L VTEC engines.
Old Jul 19, 2022 | 09:23 PM
Spaz253's Avatar
yeah thats what i ment my bad. So when I go in I just ask for a 92 Integra 1.7 L alternator? And if I want higher amp I asked for the 92 gs-r integra?
