clutch line fitting sizes?
need some help. just put a b series in a 92 eg chassis. trying to figure out a clutch line solution using the stock hardline that runs along the pass side frame rail.
i know the slave cylinder needs a M10x1 adapter to whatever the line thread is, my question is what size is the fitting on the hardline thats attached to the car?
it seems that it is either bigger than M10 or its some NPT thread.
im only doing this because im on a short time table and the local speed shp sells pre made stainless lines with various fittings on the ends.
THANKS!
THANKS!
B18c5__Owns
Mar 25, 2009 12:48 PM
