important question regarding H22 accord ECU issues
Old Apr 21, 2010 | 03:00 PM
import_tuner13's Avatar
Icon6 important question regarding H22 accord ECU issues
Hey everyone,
I have an 96 accord (Obd2) and a 97-01 h22 (Obd2) but am running an OBD1 P72 chipped and socketed ECU. upon plugging my original F22B1 ecu (Obd2) in the accord I am getting 4 misfire codes that only happen on the highway or when i rev past 3k. otherwise it drives fine. I don't think i received the CEL before while doing this this. The problem is, I live in NH and its now time for inspection. My question: Is my F22 ecu acting up? can I pass inspection running a H22 on a F22 ecu? any answers or suggestions greatly appreciated, and if you need more info let me know I will be glad to assist.
Also, to anyone out there with an H22 swap, can you run your Old ECU on your engine?
Old Apr 21, 2010 | 07:06 PM
92civlude's Avatar
Default Re: important question regarding H22 accord ECU issues
The 96 Accord uses an injector resistor. The 97 Prelude does not. Are you running the 97 H22 injectors with the resistor in place? This might be the source of your dilema. As far as running an ODD2 ECU, Its difficult to get past the immobilizer function on the 97-01 Prelude. The only OBD2 H22 ECU that will plug and play would be from a 96 H22 Prelude. It has no immobilizer.
Old Oct 12, 2011 | 08:02 AM
roboaccord22's Avatar
Originally Posted by import_tuner13
Hey everyone,
hay i have that same problem and my stickers are expired i need to take emisions to get them but i wont pass because of random misfire im running my f22b1 ecu witch is obd2 have u solved this yet.. im starting to think it the iab valve = when engage maybe got getting right fuel mixture.. i tried deleteing the restricter box but didnt help the mis..... any info please contact me robertlange84@yahoo.com
Old Oct 12, 2011 | 08:04 AM
will make it run alil better but wont help the misfire problem
Old Oct 12, 2011 | 08:09 AM
when i did the restricture box i connected all the red wires to the yellow one,,, im pretty sure thats how ur supose to ..
Old Nov 11, 2011 | 08:38 PM
has anyone firgured this out yet i am so stumped. im about to give up and sell it cuz i so far past dew on my lic sticker
Old Nov 12, 2011 | 01:03 AM
holmesnmanny's Avatar
What do you mean random misfire ? I believe the egr valve is fully open at 3k so u could clean that and the ports out.
The iab box itself tends to have holes in it. Make sure urs doesn't.
You can try some searches for resistor box I think Ghostaccord knows about it more.
Like they said, you gotta use the 96 ecu as its obd2 but without the immobilizer.
01sdime
Jul 13, 2023 01:18 PM
accordmatt
Mar 8, 2011 04:49 PM
h222accord92
Aug 8, 2007 12:10 PM
3litre190
Jul 25, 2007 01:47 AM
racerboyb18c1
Dec 29, 2003 02:52 PM
