camber with stock A-arm
I swap the Junk2 front camber kit out today because it failed again, and after I swap the stock back in, I checked my camber with a smart camber gauge on a flat floor, the reading turn out to be -2.7 (left/front) and -3.1 (right/front) aren't they supose to be the same left and right with the same ride hight? or this is normal?
i haven't played with alignments too much but when i've gone to my friend's garage the front left and right are usually different. the front left has more negative camber than the front right.
speaking of alignments i gotta get my front kit on and get my alignment done. some lady hit my car and the toe is way out on the right side. good thing i didn't install the camber kit yet so i can do everything at once. damn it's always something....
BTW, did you have the Skunk2 kit that you called the 'Junk2' kit?
later
later
itsJDMyo
13
Jan 7, 2005 10:40 AM
