1997 Acura Integra Removing ABS
Have been reading I know I need Integra RS non abs Master Cylinder, Prop Valve and 4 break Lines..
I have seen on some threads where it says I need the master cylinder n then I have seen on other where they didnt change it and just ran new lines and the prop valve..
Needing help on which parts I need for sure and prices would be helpful
Thank You
Thank You
well im doing this now on my 94 gsr because im installing a oem hid front. There are so many option when doing this. you can keep you abs boost and MC if you bend your own lines but you still bust use a 4040 prop valve. what im doing is ordered the pre bent lines for a 98+ rs and getting the 4040 from a 99-00 civic si, and also getting a 98+ MC and BB.
Does that help any?
you can get 94-97 rs parts but they wont work with 98+
Does that help any?
dustinbs144
Mar 6, 2011 06:08 PM
