Need Help with HID head light
Old Apr 20, 2010 | 10:40 PM
dc28012's Avatar
Default Need Help with HID head light
JDM conversion with HID on a 98 CW ITR. Conversion was done by myself about 3 years ago and everything worked fine until about a month ago when my driver side light went out.
I thought it was the bulb, got that check out and it worked find on the passenger side. Then I thought it was the ballast but it wasn't that either. Checked all the fuses and they are all good. I'm thinking it's an electrical problem but I don't know where to start. Any suggestions?
Old Apr 21, 2010 | 11:48 AM
mach0's Avatar
Default Re: Need Help with HID head light
fuse is fine?
Did you check the ballast? make sure your grounds are good
Old Apr 28, 2010 | 09:31 AM
CW-1194's Avatar
I had a very similar problem with my passenger side, what it ended up being was the fusebox itself. I discovered this by wiggling the fuse and the light turned back on, the connector on the fuse box was lose so I bent the prong on the fuse slightly to get a tighter fit and it has worked problem free since then.
I hope this actually helps
EG-SIXV-TEC
Lighting
Mar 10, 2011 10:57 PM
datssoled
Jul 21, 2007 06:25 PM
Magaton00si
Mar 22, 2006 10:31 PM
tallblondkid
Jan 31, 2005 10:27 AM
geminis2k
Mar 4, 2003 05:27 PM
