Ingalls front control arms fitment
http://cgi.ebay.com/ebaymotors/ws/eB...m=360252375273
I have Spring lowering springs--as of right now, the springs work fine with the OEM Honda control arms. My question is, how different are these Ingalls arms? Do you think I'll have any issues with clearance between the springs & these Ingalls components, or should they fit the same as the OE arm?
They fit the same as the OE arms. They will swing all the way up to the shock tower without ever touching the spring/shock; well, mine did, but I am running on the negative side of adjustment. Not quite sure how much clearance to the shock tower you will have with positive adjustment, but the arm will not contact the spring in any way.
1993_EJ1
Jan 5, 2011 11:51 PM
