Honda Garage Sale V2.10
All parts are plus shipping and 4% for paypal fee
Contact 786.205.3493
Eg Si OEM duckbill w/ brake light (captiva Blue paint) - $30
EG Si Sunroof Assembly $75
B Series Mechanical speed sensor - $15
OEM Fuel pressure regulator - $10
Blue anodized Oil Cap
Assorted brackets - $20 each
B16 Power steering pump - $40
Dc2 Fuel Door - $15
B series LSD Half Shaft - $50
B series Half Shaft - $40
92-95 civic Dimmer, cruise, and sunroof switch - $10
DC black Glove Box- $20
Integra Radio pocket - $10
D16 NON-vtec Valve Cover - $25
D15B Vtec Valve cover - $25
Bseries tranny mount Plate -$5
Bseries T-stat housing - $15
92-95 civic radiator fan shroud w/ motor - $20
97+ Prelude Radio w/ security code (lights up Amber)- $25
92-95 Civic Passenger side Mirror - $15
SOHC and DOHC A/c compressor (both OBD-1) - $10
Integra Cable Clutch Pedal - $20
92-95 Civic Side Tranny mount(good condition) and bracket - $25
Obd-1 VSS Sensor (top only) - $10
EG Hazards switch- $10
Injector harness Casing - $5
EG Headlight caps - $10 per Pair
Evaporator hose valve - $5
B17a1 Oil pick up - $25
Eg Rear Ashtray - $10
Ctr Crank Pulley - $45
EG Si Cluster - $40
civic/integra front strut tower bar (adjustable) - $30
B series Cable clutch (b16/17) - $25
DC Rear T Bracket $25 & Crx Bseries Tbracket - $45
Buddy Club .5mm Headgasket B16/18 - $80
B17a1 OEM Oil Cooler - $20
Bseries throttle bodies - $10 each
B16/18 Block gaurd - $20
OBD2 B20 Dizzy - $30
OBD2 P2M virgin ECU - $75
obd-0 B18 virign ECU - $50
B17A1 Vtec Solenoid - $50
Obd-1 & Obd-2 Injector Pigtails - $20ea
Dc2 Fuel Door - $15
EG Si Cluster - $40
